Petrol in a Diesel
Started by davethediver, 18 December 2009, 14:40:25
gra11
Easiest way is to either lift the back seats or boot carpet there will be an inspection plate for the fuel pump and level indicator undo that lift out the pump then sython from there saves knackering the pump from the lack of oil in the fuel ;)
If you ain't fast! Your (in a diesel)
davethediver
QuoteEasiest way is to either lift the back seats or boot carpet there will be an inspection plate for the fuel pump and level indicator undo that lift out the pump then sython from there saves knackering the pump from the lack of oil in the fuel ;)
Will have a look for that in the morning just hope it warms up a bit :)
"It is not necessary to understand things in order to argue about them."
P.A. Caron de Beaumarchais
sexydaz
gonna have my kenneth,i would drain it given the amount you put in and what the mix would be if you brimmed it.the days of the ole cavs and escorts that would put up with it are gone in my opinion the modern engine has too many sensors and ecu,s and electrical contacts(sensor to computer detect petrol,computer"oooh scream like a girl and shutdown shutdown limp mode"then yer crawl around till yer replace a diode at£946.26 which all it did is control speed yer blinker flashed at >:( >:(
bloody ell i went on there abit didnt i  ;D ;D ;D
davethediver
Well no joy with syphoning the stuff out cant get pipe in tried to drain from below and can't get the nut off that i want to release filler pipe, looks like its Nationwide and their fabulous offer of 180 quid to drain it and clean the pipes.
Just what i need the week before xmas, no PS£ for me now :'( :'(
Ken L
There is another option as a very last resort, if the fuel pipe between the fuel filter and pump is flexible rubber, you could cut it to allow the pump to pump the fuel out into a container, then put a piece of copper or alloy tubing in between the cut section to re-join it, clamp it with jubilee clips.
I say chuck a couple of jerrycans of diesel in it, get it to a garage and brim it. The fuel system has been sitting with petrol in it now, so the damage (if any - unlikely) is done IMHO.
Just fill it up with diesel dont pay £180 before Xmas or at any time  :y
davethediver
Got it sorted guys had someone come out with an electric pump thing cost 150  :( bit of a pi**er week before and all that but hey ho won't make the same mistake again.
If it was my car and not the wifes i would have just brimmed it and run it through but she didn't seem that keen.
I said can we afford it and she said yes, which means either im getting FA for xmas or shes been stock pilling cash i don't know about ;D ;D
Ken L
Glad to hear you've sorted it, bit of a pain forking out that sort of money for it, but as you say, you're not likely to make the same mistake again.
davethediver
Such is life Ken as i said if it was only worth a few hundred quid would have risked running it but at a few grand i feel it was worth is just looks like the mig will have to wait till next payday for some new tyres  ;D
kev2b4
did the same thing a few months ago - #10.00 petrol into astravan - so filled up with diesel , then kept topping up for the next few days( 600 miles) - no problems at all - normally green pump into green car , black into van
Shackeng
Ran a '36 Austin 12 on paraffin during the petrol shortage in '56. Started on petrol then ran, well walked, on paraffin. Don't recall any serious difficulties, apart from avoiding PC49. ;D ;D ;D
