Author Topic: window conversion  (Read 3245 times)
stuthespread
  • stevenage,herts
  • no spring chicken
window conversion
« on: 28 December 2009, 09:54:30 »
how easy/difficult is it to convert my rear manual winding windows to electric?
Welung666
Re: window conversion
« Reply #1 on: 28 December 2009, 11:54:43 »
Quite easy, but you'll need the following from a donor car:-
O/S rear window mechanism
O/S rear door loom
N/S rear window mechanism
N/S rear door loom
You'll also need the set of windows switches from the centre console (I'm assuming yours is a mini-facelift) and also check the loom on yours that it has the wiring for the rear windows, if not you'll need the section of switch loom also :y
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #2 on: 28 December 2009, 12:22:12 »
thanks for the info,will check to see if anyone's breaking a mini facelift. :y
Welung666
« Reply #3 on: 28 December 2009, 12:23:43 »
I know I'm a distance away but if you need help doing it then maybe we could get together and I'll do a howto at the same time :y
[edit]Just remembered you'll need the rear door window switches too ;)[/edit]
« Last Edit: 28 December 2009, 12:24:34 by Welung666 »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 28 December 2009, 12:34:53 »
Door cards as well as they dont have the holes for the winder. :y
Jaguar XJ6
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #5 on: 28 December 2009, 14:50:57 »
i've already aquired leather interior,this is why i need to convert the windows. :y
I_want_an_Omega
« Reply #6 on: 29 December 2009, 07:58:18 »
Stu,
I'll let you have the rear window switches next time I see you ......  :y
Rob
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #7 on: 29 December 2009, 09:14:14 »
lovely,just need to aquire the motors etc. ;D
I_want_an_Omega
« Reply #8 on: 29 December 2009, 19:58:13 »
Stu,
Rob
I've also dug out the centre console switches for you  :y
« Reply #9 on: 29 December 2009, 21:27:30 »
Dead easy to do, and sometimes the door looms are already the right ones......no big deal if they are not as easy to swap as there is a bloody great big connector at the bottom of the B posts
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #10 on: 29 December 2009, 21:44:40 »
I changed my doors due to rust, and the new doors had electric windows.
When going for the wiring loom connections, they just plugged into the car loom and worked straight away after adding the front switches.
best wishes
Simon.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #11 on: 30 December 2009, 21:31:23 »
That's Omegas! Everything's just where you want it to be!!
(I am excluding from that statement the Dis Pack on the V6  :y)
Page created in 0.022 seconds with 20 queries.
