Author Topic: difference between 3.0 elite and 3.0 mv6  (Read 5694 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 01 January 2010, 17:36:10 »
could anyone give a quick heads up on the diffences
between a 3.0 elite estate and a
                3.0 mv6 estate?
thanks
ken
serek
  • huntingdon
    • 3.2 mv6
idwal
Re: difference between 3.0 elite and 3.0 mv6
« Reply #2 on: 01 January 2010, 19:33:18 »
thanks for the linky - great to get information from
people who love cars.
would you consider 102,000 miles as high or still ok.
I only do around 6,000 a year so car's millage will
not increase quickly.
thanks
ken   (newbie)
goonv6
« Reply #3 on: 01 January 2010, 19:37:02 »
Its only just run in. Get James or Loo Knee on here to do your cambelt and check your rocker cover gaskets and you're good for another 150k.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 01 January 2010, 19:41:34 »
thanks
ken   (newbie)
Worked on one a month ago that had 314,000 miles on it and still going fine.
Keep it serviced well, oil changes regular, breathers clean, anti freeze, cambelt changed at proper intervals should last you for years :y
idwal
« Reply #5 on: 01 January 2010, 19:51:08 »
do they have any problems if you LPG convert them.
will be a brand new kit fitted by dealer.
will I need to do anything special in the way of servicing ect.
thanks
ken
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #6 on: 01 January 2010, 19:54:59 »
thanks
ken
There are a few guys on here who are very good with LPG....Lazydocker, Kevin Wood & James V6 they maybe able to help.
But as far as I know you just need to make sure you have a good HT side and thats it. Robwig on here is a mate of mine and got 400 miles out of his LPG tank at a cost of £30 odd  :o
« Last Edit: 01 January 2010, 19:56:05 by Loo-knee »
idwal
« Reply #7 on: 01 January 2010, 19:56:37 »
I have to admit the lpg sounds a good bet
it would make running a lot cheaper
thanks
ken
« Reply #8 on: 01 January 2010, 20:00:02 »
Ken,
LPG is worthwhile - a few of us have DIY'd.
The cost isn't worthwhile, if done at a "professional" unless the car has some real value
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 01 January 2010, 20:00:16 »
thanks
ken
The boot space suffers big time though imo :(
« Reply #10 on: 01 January 2010, 20:02:13 »
thanks
ken
Put me off for a long time that, but access to other cars helps
idwal
« Reply #11 on: 01 January 2010, 20:07:45 »
does the spare wheel go in the boot and if so can
the lpg tank not be fitted there.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #12 on: 01 January 2010, 20:14:31 »
I believe you can get a Donut Tank which goes into the spare wheel area, but I would think it would be a far less volume amount. So would be far more trips to the LPG station.....
« Reply #13 on: 01 January 2010, 20:17:10 »
much reduced range, think donut tanks are 55L, standard torpeado tanks are 80-100L
idwal
« Reply #14 on: 01 January 2010, 20:38:26 »
trouble is with the torpedo tank is if it goes behind the passenger seat it means I cannot use luggage space
cannot fold seats down ect
admittedly shorter range but tomtom is quite good at finds lpg stations and if needed could always use petrol
ken
