Author Topic: Corsa head gasket?  (Read 1710 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Corsa head gasket?
« on: 21 January 2010, 16:32:56 »
Wifes Corsa 1.4 8v 1998
Symptoms:
Mayo in the filler neck
Almost empty expansion bottle
Had a new HG fitted May 2008 when we bought it  ::)
I have refilled the expansion bottle and run the car up to temp. It runs smoothly. No sign of coolant leaks.  :y
On start up it does run a little rough  :-/
Does it sound like the HG?
If so can you recommend a supplier and any thoughts on the job. Bearing in mind I have never done a HG before  ::) ::) :y
« Last Edit: 21 January 2010, 16:35:47 by Tonkapaj »
The happiest people don't have the best of everything,
they just make the best of everything they have.
Welung666
Re: Corsa head gasket?
« Reply #1 on: 21 January 2010, 20:36:31 »
Unlikely the HG, the favourite on those is the timing chain gasket. Pop the waterpump off and feel through the opening for flapping bits of rubber from the gasket. Also try draining the oil into a clean, clear pot (tupperware or the like) and leave it 10 mins to settle. The coolant will seperate from the oil if it is getting in through the timing chain gasket.
About 5 hours work to strip it all out and replace. HTH :y
PC Techy
  • Bath
« Reply #2 on: 21 January 2010, 20:52:48 »
98 corsa 1.4 would be belt not chain , only 1.0 is chain upto 2000 year as far as i know  ;) maybe the 1.2 from 99
« Last Edit: 21 January 2010, 20:55:17 by mchiv80159 »
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
Welung666
« Reply #3 on: 21 January 2010, 21:29:42 »
Just re-read the OP, didn't see it was a 98  ::) Just ignore me then :P
