Camshaft sensor replacement job
Started by going crazy, 04 February 2010, 10:13:26
going crazy
Hello Everyone,
As some of you may be aware I need a new cam sensor and being a 4 pod with no a/c there is plenty of room and I am aware it may not be a big job but I am not always very handy with tools and also do not have any on me.
I would rather pay someone on this forum than paying a garage – as the forum has helped me immensely in more than one way.
Any body living nearer to Middlesex (TW postcodes) interested in doing this job?
Thanks for reading this post :y
i work for Sky, based at Osterley (TW8). Done 2.2 cam sensors, but not 2.0. If they are the same i can do it
Quotei work for Sky, based at Osterley (TW8). Done 2.2 cam sensors, but not 2.0. If they are the same i can do it
Same Tunnie :y
QuoteHello Everyone,
Applies to crank sensor. Cam sensor dead easy
Same Tunnie :y
Cheers Rob, EcoTec cover is screwed down from memory on 2.0. 2.2 its clipped on, coil pack connector at the back needs to come off, but since 2.0 is DIS, not needed?
Screwed down ecotec plate, cambelt cover, aux belt as usual then  :)
Same Tunnie :y
Yep :y
going crazy
Thanks Guys!! Tunnie you have a PM.
Loo-Knee was supposed to do this job on his last London visit but the same got postponed.
Thanks again for your prompt responses :)
QuoteThanks Guys!! Tunnie you have a PM.
If your getting Camshaft signal incorrect signal....dont be surprised if its still present after
going crazy
#8
Mark,
What do you reckon will be a permanant solution then? I was told the cam sensor needs replacement? I will post the actual error code in a bit- I believe it is 92 but will confirm
Edit: Yes the code is 92 Camshaft sensor Incorrect signal
Thx
