Author Topic: mother tunnies 3.0 Estate back in business  (Read 2491 times)
« on: 07 February 2010, 20:04:48 »
Past month or so mother tunnies 3.0 Elite Estate would barely get past 75 on the temp, been putting the job off for ages. But finally did it yesterday, took most of the day mind.
Big thanks to the TheBoy for giving up his afternoon (in-between swearing at his rear hand brake on his MV6)  :y
Also thanks to Daz for the handy tips on the barsteward of a coolant transfer pipe, what a kak design that is.  >:( - (no doubt its good for 'engine design' but its rubbish for basic maintenance!)
Damn good job there is not a swear pot in my garage as i could have burnt about a years salary in one day  ;D
Took it to work today and its back in business, runs at 85 spot on all most all of the time, occasionally rising to 86/87.
Economy is up too, cruise control motorway run saw 28mpg, giving it large on the way back doing 90+ 70, and red lining it away from most round-abouts saw the average drop to just 25mpg. (was reset that morning)
Mother tunnie said it felt 'free-er, and smoother' - Wonder why  ::)  ;D
Welung666
Re: mother tunnies 3.0 Estate back in business
« Reply #1 on: 07 February 2010, 20:25:35 »
Tell it was the really expensive Italian tune up it had ;) ;D ;D
« Reply #2 on: 07 February 2010, 20:51:35 »
I'll put it on the invoice  ::)  ;D
« Reply #3 on: 07 February 2010, 21:04:54 »
Your not as useless as people make out then, good work mate  :y
« Reply #4 on: 07 February 2010, 21:10:02 »
Oh i still am  ;D
Plenum, inlet manifold, plastic plate thing, not a problem, but that barstweard bolt caused problems, acess was better was the pas pipe to the pump was moved down. Managed to get it back in via luck only. Transfer pipe was a b!tch too, TB did those parts for me  ::)
Dazzler
  • Haverhill, Suffolk
« Reply #5 on: 07 February 2010, 21:40:33 »
At least its done now.
well done :y
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« Reply #6 on: 07 February 2010, 21:54:17 »
Will be doing some big miles (well for me anyway) at the end of the month so hope to do my stat before then to eke out a few more mpg.
Good to hear it went well  :y.
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
« Reply #7 on: 07 February 2010, 21:56:56 »
Well done Tunnie :y I hope your Parents appreciate you ;)
« Reply #8 on: 07 February 2010, 22:00:07 »
Cheers guys  :y
Couple of tips courtesy of Daz:
1) Take off the bracket for the PAS pump, this allows you to push the lower feed pipe down, gives useful extra room
2) Release the stat first, before taking bastard bolt out, make sure its loose, and wiggle the fek out of it (technical term  ::)) then release bastard bolt. Found its worth putting the stat bolts back in again to help wiggling that transfer pipe off.
3) Make sure you get the 2 extra O-rings for the transfer pipe, these are NOT supplied with the stat kit.
4) There are also 2 types of stats, 'thick' flange, and 'thin' flange
« Last Edit: 07 February 2010, 22:38:06 by tunnie »
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #9 on: 07 February 2010, 23:03:09 »
Well done tunnie, wish I had some of your know-how when it comes to dealing with my car :(
jonnycool
« Reply #10 on: 07 February 2010, 23:18:01 »
jonnycool
« Reply #11 on: 07 February 2010, 23:19:47 »
Bloody phone
« Reply #12 on: 08 February 2010, 01:08:48 »
Bloody phone
Echo . . . . . . . . :)
« Reply #13 on: 08 February 2010, 09:25:51 »
Cheers guys  :y
5) For the sake of a tenner or so, might be worth having a spare transfer pipe handy before you do the job, as its only a bit of cast ally, and I reckon wouldn't take much to break the bracket off.  If you don't use it, sell it on :y
