Author Topic: Wishbones  (Read 2296 times)
amba
  • Medway towns
    • German V6
Wishbones
« on: 07 February 2010, 20:07:02 »
Has anyone had any good/bad comments on "firstline"wishbones,as I need to cure the knocking from the front end and after replacing droplinks noise is still present so suspect wishbones now..its just they seem to be about the best price I have found .
Re: Wishbones
« Reply #1 on: 07 February 2010, 20:42:25 »
avoid first line full stop! except posslbly their filters, wheel barings drop links wishbones for omega and similar for BMW e39 including discs have ALL failed within 3 to 6months.
Also avoid wishbones from buy parts buy, there have been numerous failures reported on here.
Martin_1962
Re: Wishbones
« Reply #2 on: 07 February 2010, 21:23:50 »
Polybush them with powerflex bushes :y :y
amba
  • Medway towns
    • German V6
Re: Wishbones
« Reply #3 on: 08 February 2010, 17:12:05 »
So without spending a 3rd world debt(going to VX ) where would be the best place to buy from and what make would be the favoured choice ?
ians
  • Reading
Re: Wishbones
« Reply #4 on: 08 February 2010, 17:17:23 »
I would be checking for xs play first before changing them.
You sure there is not a bit of broken spring in one of the spring dishes?
davethediver
  • Blackburn, Lancs.
Re: Wishbones
« Reply #5 on: 08 February 2010, 17:19:57 »
Lemforder seems to get good reviews off people on here about 120 for a pair IIRC some decent motor factors will have them but you may have to order them  :y
P.A. Caron de Beaumarchais
Re: Wishbones
« Reply #6 on: 09 February 2010, 05:20:12 »
lemforder are the original supplier to gm
there are numerous cheapo makes, some seem happy with them, but there are alot of failures, nobody seems to be able to specify a reliable manufacturer other than lemforder. Follow the correct torqueing procedure with with car on the ground wheels loaded.
Robin Hood
  • Nottingham
Re: Wishbones
« Reply #7 on: 09 February 2010, 22:16:28 »
Tried to buy lemfoder last week but could only find one in stock (£55+ at Autovaux) with a 2 week wait for the second.   :o
Settled for delphi at £44+ instead, together with droplinks and rod ends.
Geometry tomorrow at Fleet Fit.
