Author Topic: Oil siphon ??  (Read 5737 times)
Re: Oil siphon ??
« Reply #15 on: 20 February 2010, 22:25:37 »
But... doesn't beat taking the sump plug out.
Assuming one is fitted!  ::)  ;)  ;)  ;)  :y
Was the engine designer on the bog or something when they designed the oil sump? :-/  ;D
Worth making your own, take the sump off and put your own plug on?
If I owned it - then definately!
Re: Oil siphon ??
« Reply #16 on: 20 February 2010, 22:30:59 »
The "Premium" marques (BMW etc) don't remove the sum plug for servicing ::) ::) :o :o :-X :-X
Re: Oil siphon ??
« Reply #17 on: 20 February 2010, 22:46:35 »
There are after market sumps with a sump plug fitted.
MickAP
  • South Derbyshire
Re: Oil siphon ??
« Reply #18 on: 21 February 2010, 00:48:37 »
Because I spend several hours a day driving it and treat it like it's mine - that's why. I've done 10k in the car in 3 months.
I change the oil in the Omega every 3k & SWMBO's car mid way between services also.
If I was going to get it done by a dealer then I wouldnt bother TBH as the cost would be high, but as i've got a plentiful supply of good quality GM oil then surely it can only do good tor very little £.
Anyway, the point of my OP was for peoples experience of using siphon pumps rather than WHY I want to do it.
You asked a simple question, you know your not going to get a simple answer on here ;D ;D ;D ;D
Mick :y
I_want_an_Omega
Re: Oil siphon ??
« Reply #19 on: 21 February 2010, 09:30:55 »
Indeed
I_want_an_Omega
Re: Oil siphon ??
« Reply #20 on: 21 February 2010, 09:33:53 »
I'll let you know in a day or two when I've done an oil cahnge on SWMBO's Smart ..... it doesn't have a drain plug!  :-?  :-?  :-? I bought a litre one from Machine Mart.
Thanks Andy, I'll look forward to that. Do you have a part number from MM? Had a quick look & couldn't see anything obvious
Re: Oil siphon ??
« Reply #21 on: 21 February 2010, 09:39:17 »
Pela oil & fluid extractor, order code 051716030
http://www.machinemart.co.uk/shop/range/guid/234906BB-6E8E-4A19-9D13-6107D5B9C54D  :y  :y
I_want_an_Omega
Re: Oil siphon ??
« Reply #22 on: 21 February 2010, 09:50:25 »
Thanks Andy, its the 6L one that you have gone for? I think I put sYphon into the search thing on MM - that would explain it.
Quite a bit more ££ than the ebay ones, but one that should last methinks.
Interestingly, the Kwik Fit type places charge about £45 for an oil/filter change on our Focus TDCi, so after the first use this would have paid for itself.
I'd be really interested to hear how you get on with this.
Re: Oil siphon ??
« Reply #23 on: 21 February 2010, 09:53:08 »
I went for the 6 litre just incase I ever wanted to do a lazy oil change on the Omega or Astra  ::)   ;)
Martin_1962
Re: Oil siphon ??
« Reply #24 on: 21 February 2010, 10:05:27 »
Turn it upside down then ;D ;D
waspy
Re: Oil siphon ??
« Reply #25 on: 21 February 2010, 12:10:18 »
Many already have been (Smart Tipping) ;D ;D ;D ;D :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Oil siphon ??
« Reply #26 on: 21 February 2010, 22:37:03 »
its a company car. just check the levels topup as required then when its due for service send it in. merc trucks go 100k bfore oil n filter and so do dafs on synthetic.
Hoof'land storeman.
