Author Topic: BRAKE LIGHT WARNING  (Read 6043 times)
mathewst
  • Split, Croatia
    • v40
Re: BRAKE LIGHT WARNING
« Reply #15 on: 22 February 2010, 13:13:18 »
Does the warning go out when you press the brake pedal????
The warning always appears on facelift migs when they are turned on as a matter of safety precaution
ians
  • Reading
« Reply #16 on: 22 February 2010, 13:22:26 »
Don't worry - the welds looked pretty strong  :y
;D ;D ;D ;D ;D ;D ;D
araldite is fantastic stuff isn't it.. ;)
Is it the brake light or tail light where there are actually two bulbs each side?  I know its easy to miss if just one has blown.
alunonhisown
« Reply #17 on: 22 February 2010, 13:23:59 »
Just comes up on CID that brake light warning.
Beyond Me!!!!!!
ians
  • Reading
« Reply #18 on: 22 February 2010, 13:26:57 »
is it only when you start off?
alunonhisown
« Reply #19 on: 22 February 2010, 13:28:19 »
No, all the time, I keep pressing OK and it still returns.
GRRRRRRR
ians
  • Reading
« Reply #20 on: 22 February 2010, 13:34:01 »
Might be worth buying a couple of bulbs from Vauxhall - will only cost a couple of quid.   The Omega seems particularly sensitive to aftermarket bulbs.
alunonhisown
« Reply #21 on: 22 February 2010, 13:38:24 »
Will do! Will go there today, anything so I do not have to keep pressing OK.
« Reply #22 on: 22 February 2010, 13:41:18 »
Will do! Will go there today.
Get the dash bulbs while you're at it too.
Easy job - there's a guide on here.
« Reply #23 on: 22 February 2010, 16:26:16 »
better get used to it Di, all the check items are cancelled the same way, ice warning, washer fluid low are most common and yes the brake light check is very persistant.
Also possible are head light bulb warning, brake pad low, oil level low, coolent low, headlight fied of vision(hid headlight aim has defaulted to low to avoid dazzeling other drivers) fuel low, and if you have the phone built in it will badger you to put a sim in it to enable the sos function. Tmc can pester unless you turn it off, traffic cuts in unless you turn it off, and traffic master,(i've had this added) cuts in and turns the radio on even if you turn it off for a moments piece. Keep the girl happy or she'll nag all the way home... or sometimes just koz she can. Women aye... ;D
paulsmithe
  • West Midlands
« Reply #24 on: 22 February 2010, 18:11:22 »
Cheap bulbs are a common reason for this, as has been said...
