Author Topic: Pug 406 HDi cambelt kit change  (Read 6078 times)
« on: 21 February 2010, 15:34:18 »
Has anyone here ever done a cambelt on a 2.0 406 HDi?
I've done one on the old 1.9 TD, but never a newer one.
I want to do one, ideally next Sunday - need to know if it's still a "DIY" job on these French cars...  ::) :y
PC Techy
  • Bath
Re: Pug 406 HDi cambelt kit change
« Reply #1 on: 21 February 2010, 22:01:44 »
From what i can see, the belt layout on the 406 1.9td is the same as the 2.0 hdi.
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
« Reply #2 on: 21 February 2010, 22:04:51 »
Isn't the 1.9TD an "indirect injection" setup, whereby the HDi is direct injetion.. and hence wouldn't have a mechanical injection pump powered by the cambelt?  ::) :-/  :D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #3 on: 21 February 2010, 22:06:16 »
If the job still needs that tool to compress the spring on the 1.9 I have a tool I made up for the job, yours if you want it :y
« Reply #4 on: 21 February 2010, 22:18:57 »
I wouldn't mind borrowing it mate - although - on the last TD cambelt I did - I managed without it  ::) tum de dum...  :D :y
Gaffers
« Reply #5 on: 21 February 2010, 22:22:42 »
Done it without too but so so much easier with.... and as far as I am concerned it's yours.  Never buying french again after that heap of sh.........
« Reply #6 on: 21 February 2010, 22:30:52 »
Lol = I did 60k in a 1.9td - on veg oil! Apart from being a slug, what was so bad with it?  :y
Gaffers
« Reply #7 on: 21 February 2010, 22:43:57 »
Head gasket went, once I fixed that the camshaft snapped in two :o :o
Thought it was my fault until a friend who was a metalugist confirmed that there was an air bubble in the camshaft at the point of fracture........I also witnessed french quality control when I worked in a factory for a short while over there.  2 hour lunch break where you could drink a whole bottle of wine (supplied at the canteen) and then carry on working!  We were building the isolators for the tgv power lines  :o :o :o
« Reply #8 on: 22 February 2010, 10:46:00 »
Sounds perfect. Where do I sign?
Might explain why Eurostar is so sh1te though!
« Reply #9 on: 22 February 2010, 11:26:22 »
Eurostar is fine, its the bolt on frog signaling bit that stopped them in the tunnel.
« Reply #10 on: 22 February 2010, 14:15:29 »
Admittedly it's the whole customer service experience that makes all the difference when something does fail. They truly have mastered the art of the ".. and that's my problem because?" attitude when you're stranded on the wrong side of the channel with a ticket that's printed in slightly the wrong colour ink. >:(
For that reason, the engineering might well be fantastic, but it's the boat for me every time. ;)
Omegatoy
  • UK
« Reply #11 on: 22 February 2010, 20:41:14 »
Hmm be careful James and check before you do it,
but the last HDI peugot i did required a hertz meter for the belt to be set properly!! and they aint cheap but without it being set with one the the belt isnt guaranteed against early failure!!
this was on an 806 2litre hdi but think they all the same :-/
« Reply #12 on: 22 February 2010, 20:55:59 »
Presumably that's to set the tension??
Omegatoy
  • UK
« Reply #13 on: 23 February 2010, 07:24:10 »
yep all done by the belts frquency when you ping it!!!! :y
« Reply #14 on: 23 February 2010, 10:10:45 »
Thing is - I can't see many garages having one of those, so I may do just as well do make an edificated guess as to the tension myself...  :-/
