Author Topic: Which code reader?  (Read 2209 times)
Which code reader?
« on: 01 March 2010, 14:14:42 »
I need a device that can read and reset engine trouble codes on a 2000 Peugeot 406 2.0 HDi
Live data preferable, but not essential at this stage.
Any suggestions? I don't have a clue!
Re: Which code reader?
« Reply #1 on: 01 March 2010, 14:19:55 »
A 14ld pound sledge is the best......give it a good tap but mind the body work ...
In all seriousness, it should be OBDII compliant around that age.....
« Reply #2 on: 01 March 2010, 14:22:34 »
Is there a preferable OBDII reader then? ....(not for my Omega  ;))
« Reply #3 on: 01 March 2010, 14:23:45 »
The ELM (327?) devices are ok...various bits of software for them
« Reply #4 on: 01 March 2010, 14:25:42 »
Hmm... not a standard 16 pin ODBII socket on this pug!
I'd have thought a newish commonrail engine would have had one. bah!
« Reply #5 on: 01 March 2010, 14:25:51 »
her Smart put its EML on the other day for a few iles. Next time out all was OK, it'd be nice to know why it was on.  ;)
« Reply #6 on: 01 March 2010, 14:32:30 »
Not sure they are.  2003 was the legal date for diesels, I think many companies changed around that date.
Rover, the bastards, have fitted an OBDII compliant ECU in my car, but disabled the OBDII protocol because it was sold before the 2001 date.  Needs Testbook to re-enable it.
« Reply #7 on: 01 March 2010, 14:37:42 »
Yeh but, it isn't....its a 10+ year old design.
« Reply #8 on: 01 March 2010, 14:49:43 »
Fair point... still newer than the XUD lump though!! :D
All I wanna do is read a blasted fault code  ;D
« Reply #9 on: 01 March 2010, 14:50:37 »
No sign of swarf in the fuel filter by any chance is there.......
« Reply #10 on: 01 March 2010, 15:09:47 »
No, I replaced the fuel filter on Sunday (5 min job) and had a good look in there. Couple of particles of something but no swarf.
What does this indicate - failure of the low pressure pump?
« Reply #11 on: 01 March 2010, 16:00:25 »
They suffer from low and high pressure pump failure.....and if the low presure one goes first it often takes the high pressure one with it. This means  a full clean out required, new pumps and new injectors....hence a lot around that age are off to the knackers yard....
You then get error codes related to low fuel pressure etc
And if you use them loaded regularly or tow wth them they have a habit of over heating.
