Author Topic: Big Thanks to Kevin Wood  (Read 4021 times)
« on: 24 March 2010, 08:45:54 »
For mounting my LPG injectors on the spare manifold i have (Thanks to KenT for the spare!)
Few pictures of the mounting:
Manifold ready for an injector
Starting off with a pilot hole
Pilot hole (notice amount of crap generated on this, still can't believe some 'professional' conversion garages drill with them in place)
Taking the pilot hole up to 5mm, then tapped out to 6mm
Injector mounted with some thread lock
Inside manifold, it was filled down to make it flush
All injectors mounted
All ready for fitting now  :D
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Big Thanks to Kevin Wood
« Reply #1 on: 24 March 2010, 08:50:12 »
good lad Kev x x x
may need your skills on my project when i find the right one x
« Reply #2 on: 24 March 2010, 09:00:58 »
good lad Kev x x x
Getting very personal there Daz, something i don't know about!?  :D  ;D
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #3 on: 24 March 2010, 09:19:15 »
Nice Work Kevin :y :y Looks like there will be a new LGP Omega on the road very soon..think that i may have to become a member with the price of Petrol as it is :o :o will make a big saving
« Reply #4 on: 24 March 2010, 09:21:20 »
I expect to save £10 per drive to work  :o
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 24 March 2010, 09:31:35 »
What I do like about how Kevin has drilled and tapped the holes for the Jets is the position so that when the LPG Pipes go on, the pipes will not be in the way of the bolt holes..... each one I have had the pleasure to play with is a ball ache to remove the inlet manifold bolts ::)
« Last Edit: 24 March 2010, 09:32:05 by Loo-knee »
« Reply #6 on: 24 March 2010, 09:34:45 »
We were discussing just that during fitting  :y
« Reply #7 on: 24 March 2010, 09:36:58 »
No problem, Tunnie. It was a pleasure. :y
Yes, it pays to think about that before drilling. ;)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #8 on: 24 March 2010, 09:47:49 »
good lad Kev x x x
"Booby, I probably know a lot you don't!"  ;D
« Reply #9 on: 24 March 2010, 12:02:20 »
Hopefully by the end of the weekend :y :y
« Reply #10 on: 24 March 2010, 12:05:18 »
Looking good Tunnie :y :y
Once you know you don't need the car again, get it in that garage and swap the manifolds over (as it stands is fine as long as you'll be able to get to all the nozzles)... Don't forget to swap your petrol injectors etc onto the new manifold :y :y
« Reply #11 on: 24 March 2010, 12:08:42 »
Going to swap the throttle body, but discussing with KW, he said to leave the injectors as they rarely go wrong. With luck i won't be needed them much!
Also got some new spark plugs, loads of anti-freeze so almost all set now.
Do you want to start on the front end first or tank mounting? - If i start removing the manifold, won't be able to move it if it starts to rain  :-/
« Reply #12 on: 24 March 2010, 12:18:14 »
You can always connect the rubber hoses to the nozzles, cut them off (ideally all the same length) plenty long enough to mount the injectors somewhere sensible. If you need to start the car you can then connect up the pipes to the injector rail, which will seal them.
While you've got the manifold off, remove the scuttle and make the coolant connections to the rear of the engine as discussed and leave a loop of heater hose round the driver's side of the engine bay. When you come to mount the vapouriser you can just cut this at the appropriate point and insert the vapouriser, removing any excess. :y
Petrol injectors on the drilled manifold look in good condition and were from a known good engine so I would personally leave them be to save time and avoid the risk of getting an air leak. :-/
« Reply #13 on: 24 March 2010, 12:20:07 »
Can't you squeeze it into the garage and then do it? Leave it there overnight? We'll probably work both ends simultaneously  from tomorrow morning :y
Not the end of the world... Tell you what then... Measure up the floor/chassis rails underneath and mark out on the frame where we need to drill the holes to bolt it through... This took me ages when I did mine and I still mucked it up and had to work hard to get it fitted ::)
« Last Edit: 24 March 2010, 12:22:02 by Lazydocker »
« Reply #14 on: 24 March 2010, 12:24:13 »
Could always push it. :P
