Author Topic: Cleanliness is close to godliness  (Read 2243 times)
« on: 24 March 2010, 09:34:22 »
....and removes the need to take engines apart again!
Changed a thermostat for a member on here last night as it was stuck open.
Now this particular power plant has a checkered history as mentioned on a previous thread as the engine should be a 2.6 but, it certainly has pre 98 2.5 heads fitted!
Anyway, having removed the offending stat, it became quite clear why the stat was faulty.
You can see a huge length of sealant stuck in the stat........
So, let this be a lesson to all.....excessive use of sealant is not good and cleanliness is essential!
« Last Edit: 24 March 2010, 09:37:18 by Mark »
Re: Cleanliness is close to godliness
« Reply #1 on: 24 March 2010, 09:53:07 »
i just used a small dab of grease on the o-ring when I did the stat on the 3.0, that sealant almost looks like black cam cover sealant?
« Reply #2 on: 24 March 2010, 09:54:34 »
I suspect it was cam cover sealent.....the trick with sealent is to just use a wipe of the stuff.....not so much that it ouzes out when compressed into some huge additional O ring!
« Reply #3 on: 24 March 2010, 09:57:02 »
wonder if they thought it needed it, the o-ring i got with our kit was quite thin, and did not fully fit depth / width of the grove on the stat, its been watertight though  :-/
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #4 on: 24 March 2010, 19:40:56 »
A shame, especially as it looked like a decent stat.
So, inappropriate use of (excessive) sealant and a need to do the whole job again, plus stat and a/freeze ...
Still, not sure why 'that' bolt got it's name.
-Must change my sig to 85° !
2woody
  • Northumberland
« Reply #5 on: 24 March 2010, 20:54:38 »
I reckon an engine is only clean enough to reassemble if you'd be confident licking the bits.
« Reply #6 on: 24 March 2010, 22:08:03 »
thats why my dishwasher gets so much use on engine bits  :y
Hannah Judes Dad
    • the misses round the bend
« Reply #7 on: 24 March 2010, 23:22:33 »
If I could do that I would make a fortune in films  ;D
Page created in 0.024 seconds with 20 queries.
