Pages: [1] 2 3  All   Go Down
Author Topic: LPG Project Complete! (low bandwith warning)  (Read 5982 times)
« on: 27 March 2010, 16:56:35 »
Its all done, and running perfectly on gas!  :D
Firstly huge thanks to:
Lazydocker - For giving up three days and traveling from huge distance to help me fit it, could not have done it without you. Your attention to detail and neatness, and stopping me doing bodges  :D All first class, BIG thanks  :y
Kevin Wood - for giving his evening up to drill and mount the injectors on the manifold, and for loads of advice
KenT - For the spare 2.2 manifold!
TB - Providing some tech2 after conversion to make sure all is well
All kit performed well, new drill was excellent, as was the cone drills from Screwfix  :)
It was all done by about 12 today, few other bits to tidy up, more P clips on fuel rail, and few other very minor bits, but basically its done!
I did the back end of the install, tank mounting, fuel lines, fillter, LD did the much more skilled front end, he has loads of photos of this  :)
Pictures are combination of yesterday's and todays, i have loads more than shown, available for a how2, i can zip these up for easy download  :y
Fitting tank straps
With the plastic plates to stop tank vibration, getting the straps to reach was a challenge!
Tightening them up
Boot beginning to fill with tools
Multivalve going on, one bolt did not have a thread  >:( - That did not stop LD!
Drilling vent holes, for fuel lines and loom
My hightech wedge for the drill, had to keep popping under the car to make sure i was not hitting the petrol tank.
Seal up those bare metal holes...
More tools in the boot....
Trace of orange plastic, i reckon its was off a VW Passat i re-designed 2 years back  ::)
Feeding some wires through....
My LPG install was such big news in Brackley, Sky News turned up
So i got the bacon butties on...
Used vent hose to protect certain sections of the polyflex were it might rub, also used P clip and more underseal.
Spreader plates have since been straightened, and sealed with under-seal
Bumper ready to go back on
Fat bloke fresh from holiday turned up, no shortage or spare cars!
ECU under front wing
Fuel lines in the front wheel arch going into engine, again protected by some coolant hose
Fuel Gauge
The last bolt!
Injectors mounted, front end done!
Last bolt being done up!
Tank and rear end kit all done
Stopped off after tanking up on gas, and let the mapping begin. (soapy water to check for any leaks, there were none :) )
Fully Gassed up (in my best American accent)
Diag lead mounted near airbox....
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: LPG Project Complete! (low bandwith warning)
« Reply #1 on: 27 March 2010, 17:12:50 »
well done to all concerned. a very good job indeed.
i maybe going down this route with my mv6. :y
« Reply #2 on: 27 March 2010, 17:30:05 »
It is a tidy job, plenty more space in 4 pot.
Runs well :y
Well done LD and Tunnie :y
« Reply #3 on: 27 March 2010, 18:12:30 »
No problem Tunnie and glad it worked well :y :y
I noticed TB didn't manage to hide behind the boot lid properly ::) ::)
Got home about 2 hours ago, including a fill up and having to go through town due to a road closure... Not bad time TBH. Probably something to do with a couple of c**ks who decided to try it on :-X ::) ;D
Just got to finish off those bits and it'll be done :y :y
« Reply #4 on: 27 March 2010, 18:16:43 »
Good to hear, thanks again for all your help  :y
quick question, it switched fine to petrol at 5.2k rpm on another test run, but gave some beeps trying to switch back (did not manage to count them) would not switch automatically back to LPG. Pressed the button and it switched fine back to LPG.
Any ideas? - I'll get the software loaded on my laptop and get a cable from Telio next week hopefully when i see him
Welung666
« Reply #5 on: 27 March 2010, 18:23:35 »
Excellent job fella's, looking forward to the HowTo :y
As an aside...
Bacon, brown sauce and plus-gas, my favourite sandwich ;) ;D ;D
Road Hog Mad
  • Cheshire
« Reply #6 on: 27 March 2010, 18:27:56 »
looks easy but I bet its not lol.
funny pic the 'sky news' brolley
« Reply #7 on: 27 March 2010, 18:33:28 »
I have a sneaky feeling it's the limits of the kit showing... As I said at the start, it's borderline suitability (power wise) and the pressure had dropped too low. Teilo may come up with a magic solution :y :y
You need to rotate that tank a touch before you see him (ideally)... You might get away with slackening the straps and getting a lever in (from the seats side) and rotating it like that :-/ :-/
Bet you sleep well tonight ;D ;D
Oh... And a big thanks to Mother and Father Tunnie for keeping the tea flowing when they were in :y :y
« Reply #8 on: 27 March 2010, 18:38:07 »
I'll pass it on, also pass my regards to MrsLD for some very nice cookies, and brownies, also for the time you spent here rather than keeping her warm in the evenings :)
like i say, if you ever need a garage its available, although it is a long way to come. But if you need shelter during a conversion  :y
Tempted to try rotating tank tomorrow, TB?
« Reply #9 on: 27 March 2010, 18:38:40 »
As an aside...
Don't forget a light seasoning of GM 10/40 Semi syth!  ;D
« Reply #10 on: 27 March 2010, 18:39:08 »
Useful for showers, borrowed it from my employers  :)
« Reply #11 on: 27 March 2010, 18:41:42 »
If it hadn't been for the rain I'd have made it home last night ::) ::)
« Reply #12 on: 27 March 2010, 18:44:29 »
Damn weather, it was far from a rushed job though, we did stop for a lot of tea and bacon butties  :)
« Reply #13 on: 27 March 2010, 18:47:23 »
Not enough though... You can never get enough Tea and Bacon inside you ::) :D :D
charlie
  • sunderland
« Reply #14 on: 27 March 2010, 18:54:34 »
well done to all involved,looks a very nice job even down to the painted gas filler cap :y
Pages: [1] 2 3  All   Go Up
