Author Topic: Omega pulling another Omega  (Read 2220 times)
charlie
  • sunderland
« on: 27 March 2010, 20:15:27 »
AS above would an omega pull another omega with an a frame.All so if towing an auto would the gearbox seize if towed for a long journey :y
Re: Omega pulling another Omega
« Reply #1 on: 27 March 2010, 21:21:58 »
An Omega will tow another very easily. Just take you time and allow plenty of distance to stop. If towing more than about 60 miles, remove the prop shaft, 3 bolts at either end.  :y
Page 176 http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Vehicles with automatic transmission 3
should be towed facing forwards only and
must not be towed faster than 50 mph
(80 km/h) or further than 60 miles (100 km).
If the transmission is defective, or if the above
speed or distance is to be exceeded, the drive
shaft must be disconnected from the rear axle
or the rear axle raised off the ground. In the
latter case, secure the steering wheel to
maintain a straight-ahead position
« Last Edit: 27 March 2010, 21:24:15 by Andy_B »
« Reply #2 on: 27 March 2010, 21:25:04 »
Towing on an A frame is fine, using a double axel trailer (which is what you need) and its over weight, although will still pull ok.
Autos must have prop shaft disconnected, if you intend towing 50miles or more
I_want_an_Omega
« Reply #3 on: 27 March 2010, 21:28:14 »
I've done this. I towed a 2.5 V6 auto saloon with a 2.5 V6 auto estate using an A frame and normal towbar.
No problems at all, and easier than I thought TBH
Welung666
« Reply #4 on: 27 March 2010, 21:34:47 »
Legally....
1) the towed car needs to be taxed, MOT'd and insured.
2) the towed car and A-Frame must weigh less than 750kg as an A-Frame is unbraked.
There are plenty more laws to break towing a distance with one.
Although I will admit to towing a 2.2 auto (with the prop disconnected) 100+ miles M4/M5 on an A-Frame with my old 3.0 elite estate ;)  IIRC MarkeyMark got the blame for that ;D ;D
« Last Edit: 27 March 2010, 21:35:40 by Welung666 »
I_want_an_Omega
« Reply #5 on: 27 March 2010, 21:37:13 »
In that case I broke the law several times over on my short trip to the scrap yard.  ::)
KW
« Reply #6 on: 29 March 2010, 14:39:13 »
Legally....
Not if it's on an A frame, and if it's on a one way journey to the scrappie (or an MOT/SVA that is pre booked) then the driver of the towed car only needs to be licensed and insured if all 4 wheels are going to remain on the tarmac.
Depending on when the driver doing the towing passed their test, they may well need to take another test before they can tow anything.
I know violence isn't the answer, I got it wrong on purpose.
