MarksDTM smart arse!
Started by Ronald_McBurger, 25 June 2007, 18:03:40
Well given that the the play was evident on both sides and me not being a great believer in coincidence (i.e. both sides failing the same amount on both sides simultaneously), I would still be checking the rack, I would certainly be popping the rack belows off and wiggling the wheel to see if there is any play in the inner track rod ends ......
Having said that, the tie rods are the known failure and the racks are generaly bomb proof so it may well be that.
Should have added, make sure you get the right ones as your car is right on the change over point (2004 model year)....
Ronald_McBurger
Yep, gone by chassis number
Are the PAS motor/columns the same? Nay have an idea here too.
