Author Topic: Thinking of buying a 2.5td mig  (Read 2871 times)
Miggy24
  • Exeter,Devon
« on: 01 April 2010, 18:50:15 »
Hi guys well iv seem a nice r reg 2.5td auto estate for £495 with 12 months mot.What i want to know is is there anything i should look out for or things to test out before buying. :y
Re: Thinking of buying a 2.5td mig
« Reply #1 on: 01 April 2010, 18:52:59 »
hot and cold starting.
does temp approach 100C after 2 or 3 mins of booting? If so, might be underlying issues.
Miggy24
  • Exeter,Devon
« Reply #2 on: 01 April 2010, 19:15:42 »
thanks tb sorry if im going to sound abit dumb but what do you mean by underlying issues
« Reply #3 on: 01 April 2010, 19:18:22 »
Meaning it might have been abused, oil changes are critical on 2.5TD, and if allowed to over-heat they can crack the heads
Miggy24
  • Exeter,Devon
« Reply #4 on: 01 April 2010, 19:47:32 »
Thanks Tunnie.So how often will the oil have to be changed
« Reply #5 on: 01 April 2010, 19:51:43 »
every 3k max, but doubt very few people stick to those schedules
Miggy24
  • Exeter,Devon
« Reply #6 on: 01 April 2010, 19:59:01 »
That wont really be a prob as i used to do my old mig every 5k without fail
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #7 on: 01 April 2010, 21:06:15 »
Noting TheBoy's and Tunnie's comments also:
Mine gets an engine oil/filter-change every 2500 miles religiously, and only Vx 10/40 semi-synthetic is used.
I also look after several TDs with discerning owners, and the same regime is applied to each of them.
The autos are not really economical in the fuel-consumption dept - in fact they're little better than a 3.2 V6.
Performance-wise they're, well, pretty disappointing too.
A manual-boxed (and chipped) 2.5TD is the way to go. Two of the aforementioned return a proven 33mpg around here, (note the location), and are not exactly driven like Miss Daisy either!
That said, you shouldn't go wrong at under 500 quid! :y
« Last Edit: 01 April 2010, 21:14:33 by Reliance505 »
MickAP
  • South Derbyshire
« Reply #8 on: 01 April 2010, 21:25:20 »
32mpg here just local running around, short journeys.
44mpg on a long distance m/way cruise.
Echo opinion of others here, plenty of oil changes for the diesel engine and it should be good for high mileage. :y
Mick
« Last Edit: 01 April 2010, 21:25:59 by MickAP »
Seth
« Reply #9 on: 01 April 2010, 21:30:45 »
Mick
No doubt about it if driven correctly Mick!
Click: http://www.omegaowners.com/forum/YaBB.pl?action=post;num=1266347736;virboard=;quote=30;title=PostReply
Miggy24
  • Exeter,Devon
« Reply #10 on: 01 April 2010, 22:09:53 »
are the auto`s that bad on fuel then
Seth
« Reply #11 on: 01 April 2010, 22:23:38 »
Nothing like as good as the manual-boxed jobbies!
« Reply #12 on: 02 April 2010, 09:42:34 »
the previous history of oil changes is equally important as futre service schedule, remember bmw state 4.5k max, few obeyed, most have worn chains or cooling issues now
« Reply #13 on: 02 April 2010, 09:43:01 »
oh, and change the waterpump when you get it.
Seth
« Reply #14 on: 02 April 2010, 10:07:21 »
Absolutely :y
