Author Topic: LPG Running Costs  (Read 5404 times)
LPG Running Costs
« on: 03 April 2010, 09:40:59 »
I've been asked a few times about running costs, so here goes:
Done my first work run on LPG, still need to do a little tweaking with the tank, it needs to be rotated bit further as I only got 68L in 90L tank, I want to get it up to 72/73L
My usual commute on petrol would cost me approx £26/27 each day, doing 150 miles and returning approx 30mpg, which works out at 17.3 pence per mile.
With LPG i am actually driving a further 20 miles to start with, going to a cheaper garage down the road, as its 68.9p a litre at BP around the corner, but 58.9p 10 miles down he road!  :o
Once everything is settled i will be using Asda at High Wycombe were its 54.9p litre.
But even doing 20 miles further, i did 168 miles, and used 31.06L of gas, which works out at 10.8 pence a mile, roughly 25mpg. Which gives me an effective mpg of at least 50 mpg  :D
It cost £18 for the gas, so already saving £9 per day, reckon once i start using the cheapo station on my commute and not doing an extra 20 miles, i should be on target to save £10 per day!
As is considerably less than half price at Asda, should nudge effective 55mpg  :)
Range wise, with 168 miles done, only used just over 1/3 of a tank. So once rotated and more fuel in, i expect range to be approx 350 miles.
One for the gas experts, would reducing gas pressure help mpg? Its running about 1.10 Bar currently.  :y
« Last Edit: 03 April 2010, 09:41:23 by tunnie »
Re: LPG Running Costs
« Reply #1 on: 03 April 2010, 09:48:50 »
Don't adjust pressure, as yours appears to be running perfectly (within the (limited) capabilities of your smaller vapouriser.
The pressure is all based around injector capability, nothing to do with economy/performance (in exactly same way as petrol FPR/petrol injectors)
« Reply #2 on: 03 April 2010, 09:50:45 »
Its not really missed a beat under normal driving, silky smooth switch over, and pulls well.
Only problem so far, is my hands always smell of gas now  ;D
« Reply #3 on: 03 April 2010, 09:51:34 »
My cars frequently smell of gas - its an age thing....
« Reply #4 on: 03 April 2010, 11:14:32 »
Indeed. It's just like d!cking about with 4 bar fuel pressure regulators, etc. The ECU will just trim the fuel back to where it was before. If it's running OK, leave it be. :y
« Reply #5 on: 03 April 2010, 12:40:51 »
Just wait untill you get a burn :o
« Reply #6 on: 03 April 2010, 12:43:45 »
Guessing you get one of those if that plastic neck is not on the nozzle when you release the pressure?
« Last Edit: 03 April 2010, 12:44:15 by tunnie »
« Reply #7 on: 03 April 2010, 18:45:19 »
Once you've had one you'll learn how to release the nozzles without having your hand there  ::) ;)
« Reply #8 on: 03 April 2010, 20:22:12 »
or welding gloves in boot, so you don't stink your hands out?
« Reply #9 on: 03 April 2010, 20:25:49 »
Could be an idea, as the smell is quite strong, unless its the pump i have been using  :-/
Going to try BP station next fill up, i know its expensive but interested to see if it pumps faster
« Reply #10 on: 03 April 2010, 20:31:31 »
You have a multivalve tank, it will never be quick
« Reply #11 on: 03 April 2010, 20:33:16 »
Yup, still interested to compare pump speeds though  :)
« Reply #12 on: 03 April 2010, 20:51:34 »
smelly hands? never had that.
trigger type pumps, squeeze handle and it clicks off and gas releases then twist the nozel out with the other hand ....no?
« Reply #13 on: 03 April 2010, 20:56:59 »
One i have been using so far is this on:
Releasing the handle, usual excess gas, goes every ware  :(
« Reply #14 on: 03 April 2010, 21:03:00 »
Not seen one of them !!
2 most common types shown on this site ..
http://www.lpg-vehicles.co.uk/lpg_suppliers/filling-instructions.htm
« Last Edit: 03 April 2010, 21:06:40 by entwood »
