Author Topic: About time I got around to fixing cam cover gasket  (Read 1595 times)
SJKOO01
« on: 04 April 2010, 17:49:00 »
Photo says it all really,
Was a reasonable day yesterday, so got around to fixing the slightly leaking (!) cam cover gasket  :-/.
All done now, and thankfully no leaks, mind you cost also have to get me couple of replacement rubber plug covers, and when drying them off had bit of the rubber just break off without warning !  :-?.
Was also cursing, as the rear 90deg breather hose (right at the back on the right) had the factory spring clip right where I couldn't get to it  >:( .  And also found one of the breather hoses on the the otherside was split  >:( .
Oh, and joy of all joys, found that I've got a crack in my windscreen today when cleaning the windscreen  >:( .
Let's hope when this is done, I don't have any more problems for a while now.
My custom ideas for it just seam to be getting put on hold at this rate  :-/ .
Re: About time I got around to fixing cam cover gasket
« Reply #1 on: 04 April 2010, 18:08:05 »
yup that gasket was cream crackered, hope you used genuine gaskets when re-fitting
SJKOO01
« Reply #2 on: 04 April 2010, 18:26:31 »
Oh..yes..
No short cuts here, genuine gasket, O-rings and the proper black coloured gasket sealant stuff.
Did it properly, took off all old gasket left behind, cleaned every surface off, etc.
Took my time to do it, as didn't want to rush & then so have to do it again.
Know it's only a 4cyl engine, but honesly no wonder I prefer the old school engine, there's ruddy electronic cables & sensors everywhere !.
My old cortina cover would of probably taken 15mins to do, and no cursing that you've got Opac moving in with their oil storage around your plugs !.  ;D
« Reply #3 on: 05 April 2010, 11:35:43 »
Oh..yes..
You should work on a V6! ::) ::) ::)   That's when you know you have a fight on.........with pipes, cables, cable trays, and bad design! :D :D :D ;)
« Reply #4 on: 05 April 2010, 11:55:20 »
4 pot is a doddle compared to the V6 nightmare!
Sixstring
  • Lydney, Gloucestershire
« Reply #5 on: 06 April 2010, 13:22:51 »
Them 4-potter's don't know how lucky they are!!
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #6 on: 08 April 2010, 08:18:12 »
the left side on a v6 is easy but the right side grrrrr all them pipes wiring loom and everything else you can think of to get out the way
oh and i cheated and used pat parts the first time and it punished me for it as a month later it had to have gen parts on so went straight for gen on me new v6
Used  to have  two v6 and they roared
Now got 2.5 to Opel
Page created in 0.022 seconds with 20 queries.
