Pages: 1 [2] 3  All   Go Down
Author Topic: going to look at a high milage omega 2.6.. help  (Read 8604 times)
Re: going to look at a high milage omega 2.6.. help
« Reply #15 on: 01 April 2010, 22:08:48 »
Whatever else you check .. make sure BOTH the EML and the EMISSIONS warning lights come on when the ignition is first turned on, then go out .....:)
thats the car with a spanner, and the engine shape lights.. am i right??
Yup .. both should come on with ignition... then go out after about 3-5 seconds .. :)
ChevetteNick
  • Telford
« Reply #16 on: 01 April 2010, 22:11:43 »
would the valve seals not have failed within 155k
Yes they would have done :y
« Reply #17 on: 01 April 2010, 22:15:24 »
you say that because? ...... The last cylinder head I did was on my 150 000 mile Senator. I replaced the stem seals because ... you do.  ;) They had seen better days ie they were hard, but not failed. There's no noticeable smoke on start up on my 160 000 mile Omega, & I can't see any previous owner having cahnged them for the sake of it.  :y
« Last Edit: 01 April 2010, 22:15:55 by Andy_B »
« Reply #18 on: 01 April 2010, 22:23:05 »
What makes you think that!? Bet you they have not  ;)
ChevetteNick
  • Telford
« Reply #19 on: 01 April 2010, 22:28:31 »
You answered your question yourself below ;)
they were hard
There wont be, but ask the fella behind you after you have done some hard acceleration if he could smell smoke and he will tell you yes.
« Reply #20 on: 01 April 2010, 22:28:34 »
check all the toys :  sunroof, electric chairs, windows, air condition (both for heating and cooling), cd , rear blind, mirror controls etc..
check the engine at idle both cold and warm.. if regular and no shakes,no misfires ok..  listen to any unusual noises..  can you see any leak (oil or coolant)
check the oil and coolant state..
check down the car for any repairs, traces and leaks also..
and finally check the paint closely , part gaps, front geometry must be symmetrical and gaps equal..
and drive it ..(if not possible ask the owner to drive near you) :y
ps: also the tires and wheels ..
« Last Edit: 01 April 2010, 22:31:09 by cem_devecioglu »
« Reply #21 on: 01 April 2010, 22:38:13 »
they were hard
Harder than new = could be better, not neccessarily failed  :y
ChevetteNick
  • Telford
« Reply #22 on: 01 April 2010, 22:39:26 »
Experience ;)
Do you gamble often? :)
ChevetteNick
  • Telford
« Reply #23 on: 01 April 2010, 23:10:22 »
That's some flawed thinking that is mate ;D
A new seal is soft because soft seals will seal oil better than one that is hard. Once they have started to perish they lose their effectiveness to seal oil. Once they have started to lose the effectiveness to seal oil they have failed.
« Reply #24 on: 01 April 2010, 23:18:58 »
Still don't fully agree with  you.  :y
« Reply #25 on: 02 April 2010, 09:45:05 »
That I doubt to be honest....  :-/
vxlgsi
« Reply #26 on: 02 April 2010, 12:07:42 »
so if it does smoke blue on start up, should i walk away?
« Reply #27 on: 02 April 2010, 12:16:20 »
Depends whether you want to live with it or change the valve stem seal. Seals don't cost much, but fitting them is a PITA if you have to remove heads to fit them. I don't know if it's possible to do them in situ on these cars .... never had the need to investigate.  :y
webby23
  • Nottingham
  • MV6
« Reply #28 on: 02 April 2010, 15:10:22 »
No mate, mine does it and uses about 1 litre per 1000 miles.....I can live with that.
vxlgsi
« Reply #29 on: 02 April 2010, 17:19:09 »
oh thats alright.. no way id bother changing them.. this car is to see me through the year thats all. can go to the scrapper after that ir req'd
Pages: 1 [2] 3  All   Go Up
