Author Topic: td, turbo oil mist  (Read 1749 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
td, turbo oil mist
« on: 21 April 2010, 17:51:40 »
read lots on the subject turbo oil leak, but never really seen a "how to" to cure it :-/ :). is there a solution?
hoofing it
Re: td, turbo oil mist
« Reply #1 on: 22 April 2010, 11:05:44 »
the only way to solve the problem ray is to replace it.
another tip take the jubilee clip off the hose from the air flow meter to turbo just incase it starts injesting its oil then you can starve the engine of air buy putting your hand over the pipe  some people might think its daft but the sooner you stop the engine less damage done.
Ive seen the aftermath the block was in bits only 1 piston was anything like a piston the rest were welded to the head :y
Page created in 0.349 seconds with 20 queries.
