Author Topic: Common Omega Parts List  (Read 6302 times)
« on: 25 April 2010, 13:56:57 »
Following my thread on creating a list of Omega simple Vx servicing part numbers, common across the Omega range, I now present the list covering those that I know.  Can those with the knowledge please enter others (?)
Description                                             Vx Part No.
Spark Plugs                                            009195109
Cam Cover Seals                                    090511451
'O' Ring (cover bolt holes)                       090411826
Sealant (Black for Cam Cover Gaskets)   090485251
Air Filter                                                  091149684
Pollen Filter                                              093182438
Oil Filter (Canister paper type)                  009192426
Oil Filter (Screw on)
Petrol Filter                                              025313359
Petrol Filter Clips                                      090542453
Engine Oil 10/40 Semi Synthetic               093165216
Anti-Freeze                                              093170402
Brake Fluid                                               093165410
Brake Sensor                                           090495144
HBV  (Heater Bypass Valve)                      090566947
Lock Solenoid                                           090493702
Headlight Level Sensor                              093197245
Re: Common Omega Parts List
« Reply #1 on: 25 April 2010, 14:12:24 »
Good work LZ, very good idea too  :y
markfree
« Reply #2 on: 26 April 2010, 12:28:35 »
Here's a few more to add to your list - might prevent someone having a heart-attack after trying for the umpteenth time explaining what a coolant transfer pipe is to the muppet behind the dealer counter :o
desc                                                      part-no
brake pad wear sensor                          90495144
coolant transfer pipe "O" rings               9129999
clips for bottom of front bumper            9183496
"O" rings tween breather & throttle         90500983
« Reply #3 on: 26 April 2010, 18:50:41 »
Brake pad wear sensor                                90495144
Coolant transfer pipe "O" rings                       9129999
Clips for bottom of front bumper                    9183496
« Last Edit: 26 April 2010, 18:51:52 by Lizzie_Zoom »
« Reply #4 on: 26 April 2010, 18:51:19 »
desc                                                      part-no
Thanks MF :y :y :y
Now added to main list 8-) 8-)
coastie123
  • sidmouth, devon
« Reply #5 on: 26 April 2010, 20:20:11 »
Copper sump plug washer/seal ring 11023582
Rubber sump plug washer/o-ring 90528145
Dash illumination bulbs (no seat) - 93190471
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« Reply #6 on: 26 April 2010, 20:51:56 »
Genius idea!
scream if you want to go faster!!!
Alex W
    • 2000W Facelift 2.5V6 Elit
« Reply #7 on: 26 April 2010, 20:57:19 »
This needs to be moved to the maintenance section.
« Reply #8 on: 26 April 2010, 22:15:47 »
« Reply #9 on: 26 April 2010, 22:16:28 »
Thanks Coastie! :y :y
Now incorporated into main list 8-) 8-)
« Reply #10 on: 26 April 2010, 22:17:06 »
Genius idea!
Thanks Mr Ice Man :y :y
« Reply #11 on: 26 April 2010, 22:18:00 »
Once the list is complete (if ever!!) I would agree Alex :y :y
« Last Edit: 26 April 2010, 22:18:14 by Lizzie_Zoom »
« Reply #12 on: 26 April 2010, 22:18:36 »
Following my thread on creating a list of Omega simple Vx servicing part numbers, common across the Omega range, I now present the list covering those that I know.  Can those with the knowledge please let me know of others that I should insert(?)
[/quote]
« Last Edit: 26 April 2010, 22:24:13 by Lizzie_Zoom »
« Reply #13 on: 28 April 2010, 19:55:50 »
Has no one else got, or want to make a contribution to this list?? :o :o :o :o
There must be far more "common servicing parts" than the list shows currently?? :-/ :-/ :-/ :-/ :-/
« Reply #14 on: 28 April 2010, 22:02:18 »
Lizzie, here is a copy of the parts list I have gathered for my 2.2, apologies if any are duplicated with what you have already  :y
Car Mats............................: Part No. 91132419
Paint Code.........................: Z2AU 157  (Star Silver3)
Touch Up paint...................:   "   "  91158299 (ditto)
Aerosol Spray Can..............:  "   "  91158298 (ditto)
Throttle Body Gasket..........:  "   "  90543950
Breather Sump Gasket.......:  "    "  90500571
Check Strap Bushes...........:  "    "  90462823
Cam Cover Black sealant....:  "    "  90485251
Cam Cover Gasket.............:  "    "  55558349 x1
O-Ring Gaskets..................:  "    "  90528438 x10
Anti Freeze Coolant (Red)..:  "    "  1940650/09914431 ( Approx. 6.5 Litres )
Engine Oil, 10w 40.........: Approx. 5.0 Litres
Front Brakes...............: Vented Discs (296 mm)
Rear Brakes................: Disks (286 mm)
Front Tyres................: 235/45 R17
Rear Tyres.................: 235/45 R17
Spark Plugs................: Part No. 9195109 Bosch FLR8LDCU or equiv.
Gap = 1mm, Tighten to : 25Nm (18.43ft/lbs) (216.28in/lbs
Cam Sensor.........................:   "   "  90520850
Crank Sensor.......................:   "   "  9148306
Radiator..............................:    "   "  52485464
Battery Orig. Equip..............:   "   "  19003129  (55amp/Hour)
Ignition Coil Pack.................:   "   "   9195819
Air Filter................................:   "   "  91149684
Cam Belt Kit..........................:   "   "  93174267
Cam Sprocket Locking Tool...:   "   "  KM-853 (Draper?)
Cam Belt...............................:   "   "  9128722
Fan Belt (air/con)..................:   "   "  93181718
Fuel Filter..............................:   "   "  25313359
Fuel Pump.............................:   "   "  9196213
Pollen Filter...........................:   "   "  93165208
Wiper Blade (Driver)..............:   "   "  93177183
  "     "       (Passenger.)........:   "   "  93177182
Shock Absorber(Front)..........:   "   "  72119076 (Left Hand)
  "      "       "   .......................:   "   "  72119077 (Right Hand)
Shock Absorber(Rear) ..........:   "   "  90542942
Thermostat Assembly............:   "   "  90501081
Heater Byepass Valve (HBV).:   "   "  90566947
Water Pump..........................:   "   "  24409355 (R1160032)
Exhaust Manifold...................:   "   "  24420438
EM to Head Gasket................:   "   "  24443291
EM to Downpipe Gasket........:   "   "  9157096
Ex. Manifold to Head Studs...:   "   "  24578147
  "      "    "   "  Nuts...............:   "   "  11082413
EM to Downpipe Nuts............:   "   "  9157116
EM to   "      Studs...............:   "   "  11098631
EM to   "      Gasket.............:   "   "  9157096
