Pages: 1 [2] 3  All   Go Down
Author Topic: LPG Pump Reliabilty  (Read 6681 times)
Re: LPG Pump Reliabilty
« Reply #15 on: 29 April 2010, 21:21:05 »
Pumps at Towcester working Tuesday morning.  Just as well, as I had this strange bleeping noise all the way there, and petrol gauge was falling fast ::)
some dodgy fitter installed that then, if you cant turn it off?
 :D ;D
Toying with wiring it up to the airbag, so when I run low, it will do a better job of attracting my attention...   :-[
Hard to mount the gauge in mini-facelift, mine had perfect mount point, easily viewable.
That said i do go by mileage only, as red light comes on at 310 miles, and i can do 400 to a tank of gas
i guess I could do 300+m on my (smaller) tank if I really did a motorway commute, rather than the dealing with the usual retards on the road, including the retarded council, who being a bunch of useless, incompitent retards, do the retarded thing that retards do of starting to dig up the roads during the rush hour.  I did open the window, call them a bunch of useless incompitent retards, but being the retarded retards they are, just looked back at me like a bunch of retards.
Rant over. For now.
Rant not over.  This is approximately 6 months after the senior retards aplogised on TV about being a bunch of retards, yet the retards fix the same bit of broken road, as the retards ballsed it up the first time around, and break the promise of not starting non urgent repairs during rush hour.  But being retards like they are....
Crikey TB!, I thought you said you weren't stressed enough to see a quack? :D  If you keep that up, IR you won't have any option mate  :o ;D ;) :y
« Reply #16 on: 29 April 2010, 21:24:14 »
Rant over. For now.
Good commute today then ::) ::) ::) :D :D
Don't go there.  My boss started going there this morning, as I rolled in 30mins late.  Needless to say, he quickly found something else to do...
« Reply #17 on: 29 April 2010, 21:25:47 »
I can get 350ish on a tank if commuting at about 80ish... 300 on the normal run around I do almost every time :y :y
I think I may have a problem in that case - I got 270 out of that first tank (decent 70 - 85mph commute back mostly), tank needs a tweak, but thats only another 5 litres (25m)
« Reply #18 on: 29 April 2010, 21:28:01 »
 :D ;D
Rant over. For now.
I think its appropriate to get a spot of road rage whilst in the car.  Pointless getting a bout of road rage whilst laying on the sofa, is it not?
 :P
« Reply #19 on: 29 April 2010, 21:28:10 »
Mine occasionally drops that low... Don't forget it was the first run... Virgin system, lots of idle and calibration. You'll probably find it improves over the next few tanks ;)
And 270+25=295... About right IMO ;)
« Last Edit: 29 April 2010, 21:29:28 by Lazydocker »
« Reply #20 on: 29 April 2010, 21:28:45 »
240m from last tank ::)
« Reply #21 on: 29 April 2010, 21:30:09 »
Does that mean the oil problem is cured? I may have missed an update ::)
« Reply #22 on: 29 April 2010, 21:33:20 »
No, oil problem not sorted yet.  I haven't often gone in to 3 figures, honest.  Not been floored either.  I do work in Milton Keynes, so there is a small amount of stop/start
« Reply #23 on: 29 April 2010, 21:35:19 »
I've managed to get it down to 250 when driving in town the big smoke a lot. Oh... And I've had sub 150 miles with the Pikey Box on the back! :o :o
« Reply #24 on: 29 April 2010, 21:36:48 »
mine has got better over course of a few tanks, but that could be down to weather. Managed to crack 27mpg on gas!
« Reply #25 on: 29 April 2010, 21:39:29 »
And???? ::) ::)
mpg is a useless comparison! Work in pence per mile and you realise how much you're saving ;) ;)
« Last Edit: 29 April 2010, 21:39:52 by Lazydocker »
« Reply #26 on: 29 April 2010, 21:40:51 »
And???? ::) ::)
10.6p from last tank
« Reply #27 on: 29 April 2010, 21:42:09 »
My commute is 1m through brackley, 10m on a43 at a decent cruise, drag through towcester, 50mph cruise down a5 (assuming the retards aren't being retards), then a bit of dual carriageway across MK (no roundabouts), then about 3m through Bletchley.  A commute on petrol, I easily get over 25mpg even when driving more energetically ::)
« Reply #28 on: 29 April 2010, 21:47:54 »
And???? ::) ::)
I still like to use mpg, as i can double it. With LPG being less than half the price of petrol, 27mpg means at least 54mpg  :D
« Reply #29 on: 29 April 2010, 21:49:42 »
And???? ::) ::)
flawed
Pages: 1 [2] 3  All   Go Up
