Author Topic: Ford probe 24v V6 Clutch  (Read 2688 times)
Ken L
  • Sheffield, South Yorkshire
« on: 09 May 2010, 13:35:29 »
As anyone any experience of these cars? and what sort of job it is to replace the clutch please.
   My son has decided to swap his Mondeo "Y" reg for said Probe on an "R" plate, and someone has told me the clutch replacement if needed at anytime (obviously likely at some point) is a nightmare Job, clutch kits are about £150 I've found.
  Any other views/comments about this car? I quite like the look of these actually myself, though I'm not thinking of getting one. They are basically an MX6 I'm told.
TIA
Re: Ford probe 24v V6 Clutch
« Reply #1 on: 09 May 2010, 14:27:23 »
IIRCC it's an engine out job :o :o
Ken L
« Reply #2 on: 09 May 2010, 14:42:10 »
Right yeah, cheers. thought it might be something like that.
Welung666
« Reply #3 on: 09 May 2010, 18:13:29 »
Yes engine out, Ford's version of TIS quotes 7 hours!!! :o They list the procedure as drop subframe complete with engine/box then lift engine out of subframe leaving the box still attached! BU66ER THAT!!!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 09 May 2010, 18:35:48 »
Are Probe's front wheel drive then?
Sounds a little like doing a vectra dropping the sub frame etc :)
Welung666
« Reply #5 on: 09 May 2010, 18:50:11 »
They are FWD, a popular conversion is the Mazda 626/MX-6 RWD but it's a lot of work just to swop to a proper drive train.
« Reply #6 on: 09 May 2010, 21:35:31 »
MX-6 is FWD as well, though? :-/ In fact, the MX-6 and the probe are both built on the same Mazda platform.
Welung666
« Reply #7 on: 09 May 2010, 21:37:05 »
It must be the 626 that the RWD setup comes from then. I knew it was one of them  :D ;D
tidla
  • solihull
« Reply #8 on: 09 May 2010, 21:56:51 »
cant be that bad then(with the right gear) mondeo times a bit longer. sub frame off, lower engine, box off.
hoody
  • Scotland
« Reply #9 on: 10 May 2010, 08:57:51 »
Mazda engined though,not the 2.5 ford engine.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #10 on: 10 May 2010, 09:17:15 »
according to autodata clutch replace time is 5 hours
other rides
