Author Topic: xr2 help [its a ford]  (Read 2676 times)
r1
  • nottingham
« on: 11 May 2010, 21:19:45 »
mate got a xr2 been parked up about 12months and now it wont start.hes changed lots of bits eg coil,leads,plugs and new battery and hes asked me to have a look. well took the plugs out and they nice and wet so theres plenty of fuel so checked for a spark.no spark  at the plugs,took the coil lead off and tried a plug in there and no spark,tried a lead from he battery pos to the coil pos and still no spark,
any ideas what to do next?
hoofing it
Re: xr2 help [its a ford]
« Reply #1 on: 11 May 2010, 21:21:49 »
tow start it it'll go eventualy :y
« Reply #2 on: 11 May 2010, 21:29:33 »
XR2i or XR2?
But essentially, you're looking for a spark fault. Could be a hall effect sensor, for example, depending on the set up or a duff coil ;)
« Reply #3 on: 11 May 2010, 21:32:43 »
Fords weren't still fitting contact points in those cars?? ::) ::) ::) ;)   Seem so old now! :D :D ;)
r1
  • nottingham
« Reply #4 on: 11 May 2010, 21:42:42 »
not without a spark it wont
r1
  • nottingham
« Reply #5 on: 11 May 2010, 21:46:22 »
XR2i or XR2?
its a xr2 carb not a xr2i,changed coil,does my bodge of putting a positive feed to the coil pos work. ?
« Reply #6 on: 11 May 2010, 21:51:28 »
If it's a carb version, what year? Manual or auto choke? Does it have an ignition module (little black box with, IIRCC, a 3 pin plug)?
waspy
« Reply #7 on: 11 May 2010, 21:51:37 »
Set fire to it, it'll go well then :y
« Last Edit: 11 May 2010, 21:51:50 by waspy »
tidla
  • solihull
« Reply #8 on: 11 May 2010, 21:59:11 »
if its been parked as quoted have a look at the dizzy as well.
« Reply #9 on: 11 May 2010, 22:02:04 »
Yep... But the ignition modules are a known weak point and regularly fail for no apparent reason ;)
r1
  • nottingham
« Reply #10 on: 11 May 2010, 22:37:45 »
its on a f plate not sure about ignition module any idea where this is located? any way of testing it?
didnt look at choke will have another look at it tomorrow.
« Reply #11 on: 11 May 2010, 22:42:01 »
You've got no spark so I'd say that choke isn't a big concern at present. The module is a little black box, normally attached near the dizzy. Only really able to test it with a proper coil/module tester but IIRCC they're only about £15 ;)
« Reply #12 on: 11 May 2010, 22:43:59 »
Oh... Don't think that it has one on a F plate but check for a "crank" sensor... Will probably be fitted to the bell housing at it's widest point :y
