Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: Obi-wan Project started today..  (Read 15227 times)
Re: Obi-wan Project started today..
« Reply #15 on: 28 April 2010, 09:39:32 »
So is it a 2.6 replaced with a ??
Well, it's got a DIS pack and a manual throttle... ;)
Vaders engine?
We'll know when he starts it up. :-X
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #16 on: 28 April 2010, 19:44:07 »
Vaders engine?
Close but no cigar Tunns.
TuBy's new whipping boy.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #17 on: 28 April 2010, 20:30:26 »
A couple of pictures to show what the difference is and why the spigot bearing and nylon bush are needed.
Manual 2.6
The line across the diameter is 39mm
Automatic 3.0
The line across the diameter is 44mm
« Last Edit: 29 April 2010, 13:18:33 by Loo-knee »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #18 on: 29 April 2010, 08:33:27 »
Oh yeah, and from removing the engine...is there any clue as to why it seized?
Have not got time to check yet but I got my big bar onto the Crank Bolt and it slackened with still no movement of the Crank :o so definately seized. The oil pump line on the Crank is in the 12 oclock position and the Cams look to be together and not out of sync if that makes sense, plus the tension is still on so doesn't look like that.
When I have plenty of spare time I will remove the sump and see whats welded together ;D
« Reply #19 on: 29 April 2010, 08:49:31 »
Daz, the crank dimension is not critical and changed on all engines at some point during production.
The key item can be seen in the first picture which is the spiggot bearing inside the crank drilling......this supports the manual gearbox input shaft  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #20 on: 29 April 2010, 08:53:12 »
I assumed it is the part that sticks out that the flywheel pushes onto then bolts up onto that is key? and whatever the part you have to buy from Vx creates this as it was different on the auto...
If that makes sense :y
« Reply #21 on: 29 April 2010, 08:59:31 »
Yes, with eight bolts.
Errrr :-/ Not at all  ::)  ;D   ;D  ;D
The input shaft to the gearbox sticks down the end of the crank shaft & requires the needle bearing to support it/stop it waggling about. Bearing just not required on auto.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #22 on: 29 April 2010, 09:09:16 »
well we must be getting crossed wires here.
I tried just for my own curiousity to put the manual flywheel onto the auto engine. It would not fit on. The flywheel of the manual diameter was 39mm the diameter of the auto bearing or whatever you call it on the end of the crank was 44mm. So whatever you buy fromvayxhall allows the two to marry up together
« Reply #23 on: 29 April 2010, 09:18:24 »
I'll leave that reply to Mark then  :-/. The last time I had flywheel off was years ago, but theend of the flywheel s where they should bolt to.
The spiggot bearing just fits inside the crank shaft end
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #24 on: 29 April 2010, 09:29:31 »
i dont doubt that Andy but it must allow the manual flywheel to line up on it
« Reply #25 on: 29 April 2010, 09:35:06 »
2.6 & 3.2 crankshaft are made from a different material fron the other older engines, maybe they altered the end of the crankshaft  too ..... it does appear from your photos that they have. You need the dimensions of a manual 2.6/3.2 flywheel to compare.
What are you like with a half round file?  ::)  ::)  ::) ;)
You can't be put too much on the end of the crank to make them line up or you'll alter the distance from crank to clutch face etc
edit .... I meant crankshaft .... not flywheel  ::)
« Last Edit: 29 April 2010, 10:26:23 by Andy_B »
« Reply #26 on: 29 April 2010, 10:21:05 »
Sorted.....you have a 2.6 flywheel?
You need a 3.0 flywheel
« Reply #27 on: 29 April 2010, 10:24:23 »
Phew! I am right sometimes then  ;D  ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #28 on: 29 April 2010, 11:24:26 »
'dangle berries' i need to source one then
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #29 on: 29 April 2010, 12:24:27 »
So i was wrong in thinking that all the manual flywheels were the same, but are the 2.5 and 3.0 flywheels the same and 2.6 and 3.2 flywheels the same then?
If so i am assuming that the 2.5 Vectra flywheel woukd fit ?
Pages: 1 [2] 3 4 5 6   Go Up
