Pages: 1 2 3 4 5 6 7 [8] 9   Go Down
Author Topic: The LPG kit has arrived  (Read 24330 times)
maria
  • Derbyshire
  • I'm proud to be welsh :)
Re: The LPG kit has arrived
« Reply #105 on: 26 May 2010, 22:52:16 »
So get the kettle on, then...  :-*
why put the kettle on your not here so there's not point in making a drink i got a coke so i dont need too and why dont you go and do something like put the kettle on :P
« Reply #106 on: 26 May 2010, 23:17:38 »
I have heard tell , that 'telephone *e*' is quite exciting & a nice diversion from the 'norn' with added plus that no-one else knows knows what's going on?......apart from everyone at the 'exchange, that is? but who cares when you're in Love?  ::) ;D ;D ;D ;D ;D :y
maria
  • Derbyshire
« Reply #107 on: 26 May 2010, 23:21:14 »
Exactly, thats what i say  :)
« Reply #108 on: 26 May 2010, 23:57:22 »
[/highlight]
Ahhhhhh, then all's  right with the world & his wife,  I can sleep easy?  ;D :y
andy broon
  • aberdeen
« Reply #109 on: 27 May 2010, 00:45:47 »
It is all my fault - my previous car had a system fitted but it never ran properly, wiriing shorted out and the ECU was in the air box.
It got rolled.
I diy fitted the kit into my current car about 4 years ago, took 4 weekends working carefully.
Romano System N
Needs a new evaporator.
Plastic fast injectors.
Intake is via long straws through the plenum into the inlet manifold.
would you like any parts? i have access to alot? where about do you stay?
Martin_1962
« Reply #110 on: 27 May 2010, 07:59:08 »
It got rolled.
Romano System N
Thanks
Only really need the evaporator.
And find out why it won't run WOT on gas
« Reply #111 on: 27 May 2010, 10:00:31 »
Do you have the tuning software for that ECU?
Can you watch the vapour pressure on a full throttle run and see if it's holding up?
andy broon
  • aberdeen
« Reply #112 on: 27 May 2010, 13:08:27 »
i have the software for romano systems. where in the uk are you based?
Martin_1962
« Reply #113 on: 27 May 2010, 14:24:49 »
Yes but my mains extension lead is too short.
It is flow related, car drops to petrol on full throttle.
No adjustment on evap.
« Reply #114 on: 27 May 2010, 14:50:28 »
If it drops to petrol it's probably due to low vapour pressure so vapouriser or something feeding it can't supply enough fuel.
If vapour pressure looks OK live while hoofing it it points to the injectors not flowing enough.
andy broon
  • aberdeen
« Reply #115 on: 27 May 2010, 14:59:15 »
it will all depend on the size of injectors size of the copper pipe (from tank to regulator) and the regulator presure. also have you tried changing the inline gas filter?
andy
« Reply #116 on: 27 May 2010, 15:48:36 »
Well fair shout to tinleytech, they are sending the correct item out to me FOC...
Let's just hope I can get this broken remains out the valve, tonight  ::)
andy broon
  • aberdeen
« Reply #117 on: 27 May 2010, 16:01:06 »
goodluck tonight then james.  :) :y
Martin_1962
« Reply #118 on: 27 May 2010, 16:17:11 »
andy
6mm pipe, no filter, injectors are SUPPOSED to be good enough, before the 3.0 cams I had to lean off on WOT to prevent switching - this was the advice from AGWW
andy broon
  • aberdeen
« Reply #119 on: 27 May 2010, 16:23:40 »
andy
alright well my omega is running 8mm gasline and has 2 inline filters and 3.0mm injectors. this is nothing against you, but what i have found is the gas in the south is dirtier than the gas in the north and it is recomended that you chage your gas filter every 15kmiles, but as you dont have one there could be a clog up. When was the system installed and how many miles have you done with it? it could be cutting off due to a worn diaphram or there could be a build up of gunk in ur regulator or injectors, Is the system a single or multipoint injection system?
andy
Pages: 1 2 3 4 5 6 7 [8] 9   Go Up
