Author Topic: Well guys I've turned to the dark side  (Read 6859 times)
Re: Well guys I've turned to the dark side
« Reply #15 on: 22 May 2010, 14:04:54 »
AND is has a 2 litre engine, well - 1998 or whatever.
The 316/318/320 are all the same size engine, just have different power outputs - so you call tell people that you have a 2 litre  :y
Surprising I know, but check the handbook, the 3XX is just a marketing designation
Same as the 525d, 530d and 535d all have 3.0 diesel engines after 2007  :y
I_want_an_Omega
« Reply #16 on: 22 May 2010, 14:32:41 »
Isn't dark side Diesel? In which case you would have to have a 318d to qualify .........  ::)
« Reply #17 on: 22 May 2010, 14:48:49 »
I wouldn't mind a new 320ED, 163 BHP, 8 secs to 60, 143 MPH and £20 for a years tax  :y
« Reply #18 on: 22 May 2010, 16:39:41 »
Really? so the 535d is just a chipped 530d? Thought it had its own new engine  :-/
« Last Edit: 22 May 2010, 16:39:54 by tunnie »
« Reply #19 on: 22 May 2010, 16:49:54 »
Not quite, this is how the 3 engines are:
525d - 204 BHP Small-ish Turbo
530d - 242 BHP Large Turbo
535d - 286 BHP Small Turbo & Large Turbo.
johnnycboy
  • Colchester
« Reply #20 on: 22 May 2010, 21:02:58 »
Thought you meant you'd started wearing pink crocs and listening to (p)Rick (gh)Astley CDs John. ;D ;D
Not in my lifetime ;D
Although Albs got one of my CD's which is close to rick ghastly Shite ::)
« Last Edit: 22 May 2010, 21:34:48 by johnnycboy »
johnnycboy
  • Colchester
« Reply #21 on: 22 May 2010, 21:04:02 »
07 it'll be an E90 :y
Thanks for info :y
Martin_1962
« Reply #22 on: 22 May 2010, 21:24:48 »
I thought you had gone wrong wheel drive
johnnycboy
  • Colchester
« Reply #23 on: 22 May 2010, 21:33:42 »
Still on the rear :y
johnnycboy
  • Colchester
« Reply #24 on: 22 May 2010, 21:36:07 »
That means I could have it chipped up :y
« Last Edit: 22 May 2010, 21:37:09 by johnnycboy »
« Reply #25 on: 22 May 2010, 21:38:09 »
How is the power output achieved then :question if they are all the same size lump :-/
Different sized Turbo's on the diesels, different engine mapping on the petrols, some I think IIRC have different manifolds, like your 318i will have I think 143 BHP, but the 320i I think has a different manifold and a couple of other little mods and it has 170 bhp  :y
My 5 series has a 218 BHP 2.5 engine, the 523i has the same engine but 192 BHP due to a different manifold. But again the 525i after 2007 was changed to a more fficient 3.0 engine but still retains exactly the same power output, where as the 530i after 2007 has 272 BHP with the same engine. You could probably get you petrol mapped in a slightly different way and it'd give you 320i performance  :y
« Last Edit: 22 May 2010, 21:41:43 by LSG_1 »
johnnycboy
  • Colchester
« Reply #26 on: 22 May 2010, 22:16:18 »
« Reply #27 on: 24 May 2010, 09:19:24 »
do the auto's take power increases? same box for all variants ?
mates e39 touring ate its auto box, it was chipped, but there was talk of a blocked/damaged oil cooler so not sure what the cause was.
« Reply #28 on: 26 May 2010, 22:54:28 »
Rick Astley's to blame for everything! ;D :y
Ian_D
  • York
« Reply #29 on: 27 May 2010, 20:55:16 »
I still keep thinking about changing mine for a 530d or 535d.
Its the first of the newer shape - 2003ish -> 2009ish? Which I love, but I cant really afford one yet.
What’s the running costs like on them vs 3.0 v6 I've got at the mo?
[size=12]
