Towbars...How much should i Pay
Started by Markie, 28 June 2007, 16:01:21
bob.dent
QuoteGuys I wont be doing this job. More than anything else i simply dont have time.
I have SWMBOS new car to service and replace door straps and flush coolant.
I have the Bobs old estate to coolant flush and replace door strap
I have SWMBOS discarded vectra to replace brake sensors, outside temp controller and coolant flush after its water pump...before selling.
Then maybe, just maybe, i have that pesky radiator on the v6 veccy to remove. Mr DTM where are you  ;D
Then theres the decking.... :(
:o :o :o Jeez you're a busy boy Mark, don't know how you find the time. :-?
BTW what was the final cure for the misfire - leads? Also, the coolant was only changed on the last service so it should be ok.
Markie
Number 3 lead was fubar.... :y
I`ll leave the coolant change out on the greenie then Bob  :y
bob.dent
Bug*er!! All those grazed knuckles you got doing the dispack and it was just the effin No.3 lead!! >:(
Well, at least it's sorted and hopefully running sweet again. :y
