Author Topic: Piston Rings (eBay Dispute)  (Read 2141 times)
« on: 28 May 2010, 22:20:20 »
I sold a set of rings on ebay, gen GM, as I never used them on my astra.
Chap sent me a message, saying both compression rings are there for each piston - but there are no oil rings. He states there is only the "spring" for the oil ring.
Well.... I thought, there were two compression rings, and a "scraper" ring?
Here is a picture... please advise!
Is he trying it on, or is this genuine? If they are genuinely missing, I will refund him without question.
Over to you:
tidla
  • solihull
Re: Piston Rings (eBay Dispute)
« Reply #1 on: 28 May 2010, 22:28:01 »
your pic from left to right looks like compression rings then the scrapper/spacer spring.you sometimes (generally speaking) have two thin rings above and below the spring.
see what others say...
« Reply #2 on: 28 May 2010, 22:29:41 »
that's what I've experienced in the past  :-/
« Reply #3 on: 28 May 2010, 22:30:27 »
Well if they are wrong, they can go back to the dealer!!!!!!
Too much time has elapsed to just take them back as unwanted - but if incorrectly supplied, that would be different...
tidla
  • solihull
« Reply #4 on: 28 May 2010, 22:43:13 »
not wrong, couple of bits missing.
hotel21
  • The Kingdom of Fife
« Reply #5 on: 28 May 2010, 22:47:07 »
My understanding of car pistion rings is that the oil scraper ring generally comprises of 3 parts.  Upper, flat ring, spring tensioer type ring, and lower flat ring.
If the two seperate rings are not compression rings then, its an incomplete 'set' as it were....
I would offer to readjust price accordingly, rather than offer full refund, post back, etc etc....
« Reply #6 on: 28 May 2010, 23:09:24 »
Thanks, Broocie and chaps... :)
I think, given the chaps limited English... I will not get into debate, and give him a refund with good grace  :D :y
2woody
  • Northumberland
« Reply #7 on: 01 June 2010, 10:29:29 »
a full set of piston rings consists of the following FOR EACH PISTON
top compression ring
2nd compression ring
oil control ring, comprising top ring, bottom ring and expander.
so for a four cylinder car, a complete set has 20 individual components.
