Toyota Prius?
Started by Debs., 03 June 2010, 17:39:56
QuoteDebs, looking at the posts above its better you go for a type-r..at least you wont be bored ;D
:y.....Cem, perhaps an electric type-r; a 6 volt motor on a 12 volt battery (briefly). ;D
That's captured the Type-R experience perfectly, IMHO. ;D
"This is fun, but if I carry on hitting 8.5K RPM surely it's going to let the smoke out sooner or later." ;D
interestingly the older type-r model is a robust car..and have better handling than the new model..
japs designed this car to rev the nuts off to beat the turbo rivals.. so you really need work hard.. :y
They are hard work to drive but yes, its no surprise the latest incarnation is a let down as it does not have the IRS setup of the older one.
I still fancy an (older) Type-R, always have....
QuoteI still fancy an (older) Type-R, always have....
Trouble is, they have all been ragged to within an inch of their lives....
If only the engines didn't turn backwards I would be eyeing one up as an engine donor.
2woody
(cough) S2000 'box (cough)
QuoteThey are hard work to drive but yes, its no surprise the latest incarnation is a let down as it does not have the IRS setup of the older one.
yep.. I remember they mentioned in Top Gear :y
Quote(cough) S2000 'box (cough)
Yes, has been talked about and I believe a few have done it.
Does an S2000 box output turn the conventional way or would the diff need to be fitted too?
2woody
now you've got me !
still, you could always fit both 'box and diff
But you could go backwards very fast ;D ;D
Can't you just turn the seat the other way ;D ;D
Then it'd be "Gay wheel drive" though.
