Author Topic: anyone know how to work out wheel et ?  (Read 2755 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« on: 07 June 2010, 20:08:14 »
Hi anyone know how to work outr a wheels et . I have some 8j aftermarket alloys but they don't have the et marked on them . I have measured from across the rearmost outer edge of the wheel to the mounting flange and this is 155mm . But what is the et help please ?
2001 MV6 3.2 manual been converted from 2.6 auto
Re: anyone know how to work out wheel et ?
« Reply #1 on: 07 June 2010, 20:09:49 »
I seem to recall its the distance you have measured minus half the total alloy width
« Reply #2 on: 07 June 2010, 20:12:40 »
Answered in this thread http://www.omegaowners.com/forum/YaBB.pl?num=1274910418/0
« Reply #3 on: 07 June 2010, 20:15:30 »
Which confirms what I said, thanks  :y
bigtow
  • rochester kent
« Reply #4 on: 07 June 2010, 20:15:41 »
Thanks guys
bigtow
  • rochester kent
« Reply #5 on: 07 June 2010, 21:28:23 »
Agggggggg I hope I have worked it out wrong as I make it that the wheels have a et of 53.  Which is outside of the spec for a omega apart from getting new wheels is there any way to correct this ?  :'(
hotel21
  • The Kingdom of Fife
« Reply #6 on: 07 June 2010, 22:26:00 »
Some good info on here, with a comparator as well...
http://www.carbibles.com/tyre_bible_pg4.html
2woody
  • Northumberland
« Reply #7 on: 10 June 2010, 11:47:47 »
have just read all of that - he's correct in stating the importance of rolling radius - and then goes about adding it up the wrong way.
rolling radius CANNOT be calculated. period. The only way to establish the rolling radius is to put a tyre on the rim and measure how many times it rotates in a mile. This will be different (by up to 10%) from the figure calculated by the method on that page.
tyre manufacturers do publish wheel revs per mile, but they take a bit of getting hold of.
« Reply #8 on: 10 June 2010, 11:51:39 »
rolling radius CANNOT be calculated. period. The only way to  ......
Arrrgh! FULL STOP!!!!!!!!! USA call it a bl00dy period! ........ and breathe!  ::) ::) ;)
2woody
  • Northumberland
« Reply #9 on: 10 June 2010, 11:55:54 »
I kinda wanted it to come across in the US-way, as in "extended silence to emphasise the previous point"
Page created in 0.009 seconds with 21 queries.
