Author Topic: 3.2 Air-con condenser  (Read 2879 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 15 June 2010, 14:26:04 »
Had the air-con pressure tested yesterday and they said small hole in condenser. Have just removed the rad which will now get a full flush as someone put rad weld in the system. Removed condenser and can see small amount of dye but can't see the hole. New condenser on order (£101.84 inc VAT)dealer was £250 +Vat less 15% trade card. Looks like half a birds nest of grit and twigs between fan and condenser. still will all look nice and clean when refitted. How I have missed playing with engines can't beat muck up to your elbows. Next job when parts arrive is rear discs pads and shocks. can not understand main dealer or vauxhall not having back pads in stock have had to back order on a car only seven years old. :(
Re: 3.2 Air-con condenser
« Reply #1 on: 15 June 2010, 15:28:57 »
No need for GM pads on the rear. Cheaper going to motor factor
« Reply #2 on: 15 June 2010, 16:09:36 »
You're confusing pads with handbrake shoes  ;) Pads from Vauxhall on TC are cheap, their handbrake shoes are bloody expensive  :y  :y
« Reply #3 on: 15 June 2010, 16:14:15 »
I know about the shoes Andy :y I still cannot see the need for GM pads on the rear, nor for that matter, GM rear discs either
« Reply #4 on: 15 June 2010, 16:25:27 »
TC pads for the back are £12.23+vat how cheap/inexpensive do you want them?  ;) ;)  ;)  ;)
TC rear disc/drum is £65.81+vat ..... again, not expensive at all  :y
« Last Edit: 15 June 2010, 16:26:50 by Andy_B »
« Reply #5 on: 15 June 2010, 17:06:25 »
Point I was trying to get across Andy was if the OP is ready to commence the work he may`s well get aftermarket pads rather than wait for VX  to get their finger out :)
« Reply #6 on: 15 June 2010, 17:11:32 »
Ah! I see .......  ;) :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #7 on: 16 June 2010, 07:22:47 »
Phone call last night at 17:20 pad and discs now at dealer will pick up today. New condenser should be here today for a re-build, rad has now had a good flush and all rubber pipes ckeck and good. Rear pads and discs not on trade card they told me but gave me 9% off.
« Reply #8 on: 16 June 2010, 08:13:36 »
Oh yes they are
Ventilated discs/drums from '01                              93182287 £94.00 £80.15 £68.05
All models disc pads                                93169001 £20.75 £18.68 £12.23
« Last Edit: 16 June 2010, 08:31:02 by RobG »
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #9 on: 17 June 2010, 20:59:07 »
Picked up the discs and pads yesterday and the man said they had over charged me discs 93182287 £68.05 :y
pads diffo No.9195058 £49.60 :-?
Have they given me correct pads as i have not looked yet. >:(
