Author Topic: oil burning piece of junk !!!!  (Read 5068 times)
Re: oil burning piece of junk !!!!
« Reply #15 on: 07 July 2010, 13:56:09 »
Sadly not, difficult to explain but its related tot eh fact that the cast tubes the leads fit through are at an angle.....so when you fit them on the opposite head the angle is the wrong way so stresses them.
To the original poster....were the cam cover gaskets original Vx from a VX dealer or were they another source?
« Reply #16 on: 07 July 2010, 14:12:32 »
Also was it DIY done or by a garage? Was any sealant used on the bridges, and were the cam covers torqued correctly to 8Nm with a torque wrench?
« Reply #17 on: 07 July 2010, 18:37:28 »
If the covers have been replaced with known good ones, I suspect the issue is either workmanship or substandard parts to be honest  :'(
« Reply #18 on: 07 July 2010, 19:32:40 »
.. or the breathers aren't really clear from end to end. I know they've been checked, etc, but  something is wrong. ;)
pedroMV6
  • York
  • Der Metzgermeister
« Reply #19 on: 07 July 2010, 22:30:54 »
If everything else is completely spot on, then would it be worth totally removing the breather, taking it apart and looking inside and maybe giving it a proper clean?
Also, have you squirted some carb cleaner in it when changing the gaskets?
OK, you'd need an oil change after.
v6fletch
« Reply #20 on: 07 July 2010, 22:34:01 »
it had the breathers cleaned less than a month ago,new vx gaskets etc fitted by a vx mechanic,trying a set of brand new covers from a gen vx garage/dealer this weekend
