Author Topic: Anyone ever changed a reluctor ring on a Rover?  (Read 5231 times)
« on: 31 July 2010, 22:40:05 »
I have just failed miserably at the first hurdle - I couldn't even remove the ABS sensor  :-[
I would have failed at the 2nd hurdle as well, as I can't find my balljoint splitter  :-[
Unless anyone knows a way without removing the bloody hub?
Re: Anyone ever changed a reluctor ring on a Rover?
« Reply #1 on: 31 July 2010, 23:12:44 »
And I've spent most of the day on it  :-[, apart from a brief chat with Auto Addict, which was a welcome break, seeing as I was looking for Sammy at the time ;D
« Reply #2 on: 31 July 2010, 23:16:07 »
Front or rear?
I assume front?
« Reply #3 on: 31 July 2010, 23:17:06 »
Yeah, front...
« Reply #4 on: 31 July 2010, 23:18:05 »
Certainly the OSF, the ring is split, presumably thats what causes the ABS to constantly fire under breaking, which Mrs TheBoy finds somewhat disturbing....
« Reply #5 on: 31 July 2010, 23:27:47 »
Is it CV joint mounted (I guess it will be)
Split ring will cuase the ABS to fire every time you brake
« Reply #6 on: 31 July 2010, 23:30:37 »
Yup, mounted hub side of the CV.
Implication is you can remove hub, clean it up, then drift a new one on...
« Reply #7 on: 31 July 2010, 23:39:41 »
Or remove CV joint.....heat the new ring up on the stove.....it should just drop on (with a light tap, clean the face of the CV joint up well)
hotel21
  • The Kingdom of Fife
« Reply #8 on: 31 July 2010, 23:41:35 »
Keep the new CV joint in the freezer overnight as well...   ;)
« Reply #9 on: 31 July 2010, 23:44:19 »
Sounds like hes using the old one....
« Reply #10 on: 31 July 2010, 23:44:54 »
.....the tight bugger  ;D
hotel21
« Reply #11 on: 31 July 2010, 23:47:15 »
Aye, squeeks when he walks, that one...  Either way, an overnight at minus 18 or so will increase the normal tempt interferance fit tolerances.  ;D
« Reply #12 on: 01 August 2010, 09:37:32 »
Still have to remove the hub though?
Might have to get out the camping stove, assuming halogen hobs aren't ideal for that ;D ;D ;D
« Reply #13 on: 01 August 2010, 10:49:46 »
Have two Rover 25 diesels in the family, i've changed quit a few CV joints. You have to undo the bottom ball joint.
I bought these last time and they've been ok.
http://cgi.ebay.co.uk/ROVER-25-2-0TD-CV-JOINT-NEW-99-ONWARDS-/130358306961?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e59f5e891
My 25s haven't got abs so I removed the rings which come off really easy but don't know what they'll be like to remove after being on the car for a while.
« Reply #14 on: 01 August 2010, 11:02:43 »
I suspect the one one, being split, will pop off nice and easy. Probably need a lot of cleaning up to remove all rust from that area.
Bit reluctant to change the CV itself when its not showing any signs of needing replacement, and putting on a potentially inferior pattern  :-/ (hence why I bought the rings only)
