Author Topic: Lower Suspension Arms  (Read 3115 times)
andyc
  • Norfolk
« on: 04 August 2010, 12:04:23 »
Ok following on from other posts about the cost of lower arms i've come up with the following. You may be able to get them cheaper but this is an FYI
Single Genuine GM Suspension Arm
Arm £205.09
Horz' Bolt £2.75
Vert' Bolt £2.42
Nuts x 2 £4.22
Total 214.48
Pair of Genuine GM Lower Arms
Arms £185.25 ea (£370.50)
Horz' Bolt £2.33 ea (£4.66)
Vert' Bolt £2.06 ea (£4.12)
Nuts x 4 £1.64 ea (£6.56)
Total £385.84
Re-Bushing of Orginal Arms ( you'll need a press)
Single Arm
Horz' Bush £24.41
Vert' Bush £12.52
Horz' Bolt £2.75
Vert' Bolt £2.42
Nuts x 2 £4.22
Total £46.32
or
£74.47 with ball Joint ( B/J @TC Price)
Pair of Arms
Horz' Bush £19.79 ea (£39.58)
Vert' Bush £10.12 ea (£20.24)
Horz' Bolt £2.33 ea (£ 4.66)
Total £75.16
or
£131.46 with Ball Joints (B/J@TC Prices)
Lemforder Arms
Single Arm
Arm £83.99
Horz' Bolt £2.75
Vert' Bolt £2.42
Nuts x 1 £4.22
Total £93.38
Lemforder Arms
Pair of arms
Arms £77.08 ea (£154.16)
Nuts x 4 £1.64 ea (£ 6.56)
Total £169.50
Ok now the offical parts
All parts are subject to VAT @ 17.5%
Postage Via DHL UK Mailand £6.90 + VAT (will need to be signed for)
All arms and bushes WILL be supplied with new nuts and bolts
Offer can/will withdraw at any time without prior notice
Hope this helps
Cheers
Andy
Thetford. Norfolk
Re: Lower Suspension Arms
« Reply #1 on: 04 August 2010, 12:08:21 »
Might be wrong but I thought Lemforder supplied GM with the wishbones :-/ :-/
« Reply #2 on: 04 August 2010, 12:12:41 »
as said before ......
Heinz suplly HP beans, but they're different from Heinz Beanz (well, the beans are the same but the sauce is different  ;))
« Reply #3 on: 04 August 2010, 12:17:00 »
So what`s the difference (apart from price) between Lemforder bones and "genuine" :-?
« Reply #4 on: 04 August 2010, 12:19:13 »
That's what we all want to know.
But first off, huge thanks for posting this Andy. :y
« Reply #5 on: 04 August 2010, 12:25:58 »
 :y  :y  :y  :y  ;)
« Reply #6 on: 04 August 2010, 12:27:13 »
Maybe AndyC has the answer
« Reply #7 on: 04 August 2010, 12:33:43 »
Excellent info. :y
Makes me wonder if it's worth investing in a press and a load of genuine GM bushes as they appear to be not that unreasonably priced?
Then again, they are an absolute 'stard to press even then, IME, and I think there'd be an attrition rate of arms getting knackered in the process. :-/
Might be worth just resolving to feed it a pair of 25 quid arms every couple of years? (Plus alignment afterwards, of course) :-/
« Reply #8 on: 04 August 2010, 12:34:56 »
Just a note on bolts, there was some discussion as to weather these are supplied with lemforder wishbones, they are not, the nuts for the bolts are supplied, as are the the nut and bolt for the steering knuckle end. But no bush bolts....
As in the pair delivered from all German parts with sealed bags, the bolts had not been lost from the bag.
« Reply #9 on: 04 August 2010, 12:36:56 »
Then again, they are an absolute 'stard to press even then, IME, and I think there'd be an attrition rate of arms getting knackered in the process. :-/ ......
Not too difficult with suitable sized drifts & do-nuts underneath to support the actual wishbone.
