Author Topic: 206 wishbones ?  (Read 2708 times)
omegod
  • liverpool
    • 2017 Seat Ateca
206 wishbones ?
« on: 05 August 2010, 12:25:12 »
Pickep up a clean 206 for a song, it needs wishbones for the MOT , heard these can be a ghastly nightnmare to get off which will involve a 5 foot scaff bar and chains! anyone done these?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: 206 wishbones ?
« Reply #1 on: 05 August 2010, 16:32:58 »
I will let you know tomorrow as I have a 206 outside waiting for wishbones to arrive :y
other rides
omegod
  • liverpool
    • 2017 Seat Ateca
Re: 206 wishbones ?
« Reply #2 on: 05 August 2010, 20:02:38 »
best of luck Henry, I would put this on the same peg as an ATF change on the Miggy.
One bolt wont clear the driveshaft drivers side and I just cut the other one off with a grinder. Spring compressors would make it a lot easier!!
Nightmare  >:(
spud1990
Re: 206 wishbones ?
« Reply #3 on: 05 August 2010, 21:45:56 »
they aint that bad 2 do. i take the bottom of the strut out the hub then take the ball joint bolt out and remove the bottom arm. would change them 4 u but im showing my car this sat at castle combe :y :y :y :y
henryd
  • west cornwall
Re: 206 wishbones ?
« Reply #4 on: 05 August 2010, 22:06:30 »
Nightmare  >:(
best I empty my swearbox first then :P :'(
other rides
David.R
  • Dorset, Hampshire, West Sussex
Re: 206 wishbones ?
« Reply #5 on: 06 August 2010, 10:50:32 »
I've changed a set of 206 wishbones away from my workshop with nothing more than a socket set.  You have to fiddle about a bit to make sure you don't pull on the driveshaft too hard while the bottom ball-joint is disconnected, but other than that it's reasonably straightforward.  2hrs from car driving all over the place to car driving in a straight line.
henryd
  • west cornwall
Re: 206 wishbones ?
« Reply #6 on: 06 August 2010, 15:57:09 »
just finished the 206 that I am doing,I removed the hub nut and swung shaft out of the way which gives access to front bolts,left hand side was easy but struggled a bit with the right hand one getting the arm low enough to re-engage ball joint pin,enjoying coffee and fag break now :y
other rides
omegod
  • liverpool
    • 2017 Seat Ateca
Re: 206 wishbones ?
« Reply #7 on: 06 August 2010, 17:10:01 »
All done myself too, bit of a faff but saved a few quid :y
