Author Topic: y3.0 cams  (Read 2469 times)
andy_driver
  • coatbridge
  • my omega had 7 of them + my 74 mini clubman estate
    • my omega of course
    • http://i746.photobucket.com/albums/xx101/andymoto29/omegapic1.jpg
y3.0 cams
« on: 07 August 2010, 20:12:41 »
finally got a hold of a set of 3.0 cams and injectors today out of my local scrapyard 80.000 miles at £40 quid  ;D. cant wait to fit them doing it tommrow sundat morning job keep me quiet for a few hours lol
koni adjustable shocks eibach 30mm progrssive rate springs goodridge braided brakeline kit ebc redstuff ceramic brake pads all round black diamond drilled dics at front k+n panel filter  steinmetz body kit
Re: y3.0 cams
« Reply #1 on: 07 August 2010, 20:14:33 »
Are 3.0 Injectors different to 2.5 versions?
andy_driver
  • coatbridge
Re: y3.0 cams
« Reply #2 on: 07 August 2010, 20:18:14 »
well the last time i look at mine there were yellow ones . am asuming there a diferent fuel rate but will look at tommrow and will find out the part numbers
Re: y3.0 cams
« Reply #3 on: 07 August 2010, 20:49:45 »
I think the injectors are the same. Colour of the body doesn't necessarily have any relevance but it would be interesting to compare the part numbers. :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: y3.0 cams
« Reply #4 on: 07 August 2010, 22:24:16 »
i believe they are the same. :)
andy_driver
  • coatbridge
Re: y3.0 cams
« Reply #5 on: 08 August 2010, 20:54:43 »
well fitted my 3.0 cams today . and had a look at the numbers on the injectors . (2.5 injectors 0 280 155 712  c 961 8 862 ). (3.0 injectors 0 280 155 712 e 060 663 ) . so there looks as thow ther is some kind of difference . fitted the 3.0 ltrs ones anyway
Re: y3.0 cams
« Reply #6 on: 08 August 2010, 22:22:45 »
0 280 155 712 is the Bosch part number so they are both the same.
Flow rate 203.9cc.min @ 3 BAR. :y
andy_driver
  • coatbridge
Re: y3.0 cams
« Reply #7 on: 09 August 2010, 18:38:40 »
does anyone know what the numbers mean after the part numbers i posted
Re: y3.0 cams
« Reply #8 on: 09 August 2010, 21:11:11 »
Probably manufacture date / batch codes I would have thought.
