Author Topic: Modifying a 2.5v6!?!?!  (Read 5314 times)
Re: Modifying a 2.5v6!?!?!
« Reply #15 on: 04 September 2010, 22:03:29 »
I think Phil (Skruntie) suspected you were trying to circumvent the rules relating to the 250 post count when you enquired as to the availability of the cams. As suggested, if you put a wanted ad in the "Test" zone with a request for one of the Admins to move to relevant section all will be forgiven ;) :y
« Reply #16 on: 04 September 2010, 22:08:34 »
Sent trigger a detailed PM plus a bit more info.  :y :y
mh_trigger
« Reply #17 on: 04 September 2010, 22:09:04 »
ooooooooooo.....i dont really want the cams yet.....i keep gettin myself into bloody trouble.......suppose rules are meant to be broken tho    :D :D :D :D
« Reply #18 on: 04 September 2010, 22:13:32 »
They hunt you down and delete your posts on here, they are keen on rule breakers.  (and non rule breakers, I just lost 22k posts, and did sod all wrong )
mh_trigger
« Reply #19 on: 04 September 2010, 22:15:45 »
skruntie.....thanks for the pm......its makin more sense......i have got several post stick notes dotted around comp now of donts and donts  ;D
« Reply #20 on: 04 September 2010, 22:20:58 »
Star man  :y , easy omce you know how and easy for Admin and Mods as generally they leave the posts alone unless some one starts to be naughty.
« Last Edit: 04 September 2010, 22:21:34 by skruntie »
mh_trigger
« Reply #21 on: 04 September 2010, 22:26:20 »
hmmmmm............naughty.......
« Last Edit: 04 September 2010, 22:26:33 by Matt_H »
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #22 on: 05 September 2010, 00:17:32 »
This member is breaking a 3.0ltr. May have them :-/
http://www.omegaowners.com/forum/YaBB.pl?action=viewprofile;username=2232292B28252124400
That'll be me then!
I do have a set of cams however I was hoping to sell the engine and auto box together for around £300...
mh_trigger
« Reply #23 on: 05 September 2010, 00:26:38 »
pm sent brick
tidla
  • solihull
« Reply #24 on: 05 September 2010, 00:45:48 »
mh_trigger
« Reply #25 on: 05 September 2010, 01:09:52 »
He's proper tall! ;D
ballcock50
  • South Wales
« Reply #26 on: 05 September 2010, 11:05:38 »
3 ltr cams give about a 0.8mm extra lift so should effect valve timing by opening earlier and closing later. yes they do help.
mh_trigger
« Reply #27 on: 05 September 2010, 16:20:34 »
0.8mm!!!doesn't sound a lot but that's quite considerable! :y thanks for the info!
