Author Topic: Ford focus problems 1.8 T reg  (Read 2811 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
« on: 03 September 2010, 11:34:56 »
Its not a big deal but its really annoying. The car revs up to about 2k of its own accord and between gears it doesnt seem to drop the revs as much as it should. Ive cleaned out the throttle body any other ideas. Cheers Rik
regards Rik
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Ford focus problems 1.8 T reg
« Reply #1 on: 03 September 2010, 11:50:05 »
engine management light on or not?,vehicle speed sensor can cause these problems and the speedo will still work,may be worth getting any codes read
other rides
rikki_essex
  • essex
« Reply #2 on: 03 September 2010, 11:52:58 »
no light on all at all mate
regards Rik
henryd
  • west cornwall
« Reply #3 on: 03 September 2010, 13:19:14 »
I would still try a code read if you can
other rides
Jinglemaster2
« Reply #4 on: 03 September 2010, 13:22:07 »
Typical Focus air leak I suspect. MAF sensor is also a good place to look.
« Last Edit: 03 September 2010, 13:52:45 by Jinglemaster2 »
armandjones82
« Reply #5 on: 07 September 2010, 07:42:46 »
Try to get some good ford focus parts for that one in order to fix it. If not, try to really find some ways to fix that problem, otherwise it will really act up frequently.
mh_trigger
« Reply #6 on: 07 September 2010, 23:28:14 »
please please please dont waste any money on diagnostic plug ons!this is a common focus problem.there is a breather hose either:
1) in the loop of the inlet manifold
2) just at the rear/bottom of the throttle body.
These go soft and crappy with the oil fumes which then tears/rips creating an air leak.please dont waste any money on diag untill youve checked them out! :y :y :y
rikki_essex
  • essex
« Reply #7 on: 08 September 2010, 09:02:19 »
Will do thanks very much. I think it will have to wait for a couple of days as i get married on Saturday and as you can imagine theres lots of other bits to sort out.
regards Rik
rikki_essex
  • essex
« Reply #8 on: 08 September 2010, 09:06:12 »
Just another quick one will these be noticable to a complete moron under the bonnet
regards Rik
zirax
« Reply #9 on: 08 September 2010, 10:00:44 »
If looking at the above doesn't sort it...
ring up ford and check that yours had the recall for the revving issue. With my V reg 1.8 there was a free ECU update that would sort something very similar out to what you are experiencing.
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
rikki_essex
  • essex
« Reply #10 on: 08 September 2010, 18:57:48 »
I know its really cheeky but is there any one near me that i could pop round with the car and can have a look under the bonnet as i hate taking it to any garage just to get screwed over. I will only be back from all the wedding stuff in about two weeks time. So if any one is about i would really appreciate it. Rik
regards Rik
