Author Topic: FWD OR RWD?????  (Read 15695 times)
Re: FWD OR RWD?????
« Reply #15 on: 06 September 2010, 22:31:57 »
For me FWD would always be the option with a small car like a Corsa as you can push them to the maximum, into and around corners, along twisting roads.
The drives I had in my sons and daughters Nova and Corsa, let alone in the company owned Cavalier SRi! 8-) 8-) 8-) 8-) 8-)  Tried the same in a then new Carlton RWD 1.8 and ended up spinning 540 degres up a M4 slip road! :o :o :o
Yep, I recommend FWD! :D :D ;)
Re: FWD OR RWD?????
« Reply #16 on: 06 September 2010, 22:33:05 »
I recommend you to try a small, light car over 200 hp with rwd..you will see its not a joke when you hammer it..
for those light cars fwd is a lot safer..
« Last Edit: 06 September 2010, 22:35:41 by cem_devecioglu »
Re: FWD OR RWD?????
« Reply #17 on: 06 September 2010, 22:35:10 »
you were lucky Lizzie.. you could end up with a tree even.. :-/
mh_trigger
Re: FWD OR RWD?????
« Reply #18 on: 06 September 2010, 22:37:36 »
ok this is getting harder and harder to decide!does anybody know what body/chassis mods will need to be done to run rwd? :-[
Re: FWD OR RWD?????
« Reply #19 on: 06 September 2010, 22:37:42 »
Yes Cem, I was very lucky, as I only damaged a wheel cover when it touched a kerb!! :o :o :D :D ;)
Jinglemaster2
Re: FWD OR RWD?????
« Reply #20 on: 06 September 2010, 22:41:40 »
I catually drove a Corsa C with the 2.5v6 in last year. It was hell. Torque steer was frankly horrendous as you would imagine. The only car I ever drove that had worse torque steer was Laidbacks Saab Turbo. I will never forgive him for not mentioning that the steering column will come off if you floor the car, and the seta was not attached either.
Martin_1962
Re: FWD OR RWD?????
« Reply #21 on: 06 September 2010, 22:42:14 »
I have seen small RWD cars with nearly 300bhp and they handled fine.I think this might be it
[media]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/WanAC8f9Ufs?fs=1&amp;hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WanAC8f9Ufs?fs=1&amp;hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/media]
http://www.youtube.com/watch?v=WanAC8f9Ufs
« Last Edit: 06 September 2010, 22:42:42 by Martin_1962 »
Martin_1962
Re: FWD OR RWD?????
« Reply #22 on: 06 September 2010, 22:43:44 »
Never had problems down twisty roads with RWD, and the only time I had full slide the back tyres were a dodgy brand
Re: FWD OR RWD?????
« Reply #23 on: 06 September 2010, 22:45:24 »
imo, the car chasis and weight distribution are designed at the factory according to rwd or fwd..
not very simple..
mh_trigger
Re: FWD OR RWD?????
« Reply #24 on: 06 September 2010, 22:51:30 »
http://www.youtube.com/watch?v=wJYKqBizLH0&NR=1
i dont wana do this tho! :'(
Martin_1962
Re: FWD OR RWD?????
« Reply #25 on: 06 September 2010, 22:53:29 »
Weight distribution - the more 50/50 it is the better a car is at corners, so putting a gearbox in the middle does help.
Some Alfas and the latest GTR have rear mounted boxes for weight distribution
mh_trigger
Re: FWD OR RWD?????
« Reply #26 on: 06 September 2010, 23:00:48 »
now that sounds even more intense than just makin it rwd! :-[
mh_trigger
Re: FWD OR RWD?????
« Reply #27 on: 06 September 2010, 23:02:04 »
im wondering if i push the engine and box as far into the cockpit as possible that would do sortof the same?!?!?!?! :-?
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: FWD OR RWD?????
« Reply #28 on: 07 September 2010, 00:10:36 »
...people keep planting seeds...
david036
  • Lancashire
Re: FWD OR RWD?????
« Reply #29 on: 07 September 2010, 00:34:30 »
Has to be RWD, although the weight issue on a small car could make it 'interesting'  But this can be sorted very quickly, just like the old plod 3.0l cappri's - a lump of concrete in the boot.  I'm sure and LSD will help as well!
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
