Have you seen the mileage on this !
Started by Hannah Judes Dad, 15 September 2010, 09:40:31
QuoteThey are good engines, just let down by dodgy fuel pump electronics.
You must be thinking of the 1.7
Not on the 2.2Dti.
It can suffer pump internal seals and diagphram issues but most of these can be avoided if the fuel filter is changed regularly nad the water drained from it.
Is it not the same 2.2 diesel eco-tec lump (y22dth) as found in Vectra b's and c's?
They have an electronic control board mounted to the side of the pump, which itself is bolted to the block. The electronics suffer due to heat and vibration. It is a known issue on 2.0 and 2.2 diesel Vectra's...
Never causes any issues on the Omega.
In fact, past experience sudgests its only a significant issue on the 1.7's and is very often WRONGLY diagnosed as the cause on the 2.0 and 2.2 as a result.
I have seen loads sent for testing with NFF  :y
M20LSY
QuoteThe older 1.7 Isuzu lump is a good engine, the 1.7 G.M. unit, out around the same time, is not so good...
...same as most Vauxhall engines..  ::)
Danny
it only had a gearbox and clutch fitted at 270,000, so its done fantastic to get that far without them!!
waspy
It shows testament to that engine :y :y
Mine's only done 91,000, i've only done 11,000 in three years of ownership. I wonder how many years it'll take me to get to 347,000 ::) ;D
Seen quite a few DTi Omegas with well over 250K on them, one went on Ebay with 478K recently.
unclelicklug
This must be near me - tempting to go and have a look, wonder if I can find the address on Auto Trader...
waspy
QuoteSeen quite a few DTi Omegas with well over 250K on them, one went on Ebay with 478K recently.
Buddy L :o :o :o :o
tidla
Not on the 2.2Dti.
filters full of that wont help. ::)
It was on Ebay the same time as my Desmond ::)
dervdoc
iv a 89 w124 300d merc. 3.0 straight diesel, auto box, serviced every 3k miles from new, 1 owner from new, i got it off my uncle, we hyave added up theres roughly over 700k on this engine, has had 3 dash units so just adding up miles on them, engine had never been touched nor the auto box, although im stripping engine down now as signs of wear and tear have begun to show.
