Author Topic: Help with zafira warning light  (Read 2896 times)
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« on: 21 September 2010, 22:57:02 »
A friend has a 2000 2.0dti zafira and the eml and coolant (looks like a radiator with a star in middle) light is on and the rev counter drops to zero it also runs rough and goes into limp mode.
I've read the codes and none are stored or present although the lights are on.   The lights do go out and the car runs fine for a while and then return.
Question is do any of you know anything about zafira dti's and ccould you give me some ideas of what to check/do to fix it.
Thanks for looking
Lee
Re: Help with zafira warning light
« Reply #1 on: 21 September 2010, 23:03:55 »
Question is do any of you know anything about zafira  ......
We know someone with a Mummy Bus .......  ::)  ;)
lee4206
  • southampton
  • Mot Tester
« Reply #2 on: 21 September 2010, 23:06:26 »
How did you know i have one as well ;D :D
Welung666
« Reply #3 on: 22 September 2010, 05:59:56 »
Try the pedal trick, as it's an earlier model it may well work. Otherwise it's a code reader for a detailed list of faults.
hoofing it
« Reply #4 on: 22 September 2010, 06:50:46 »
if its the earlier version i'd be looking at the fuel pump or imobiliser.
is it not the same engine as fitted to the vectra B  :-/
Welung666
« Reply #5 on: 22 September 2010, 07:41:51 »
Yes, VecB and ZafA share the engine. Needs the codes reading first rather than guesses ;) :y
lee4206
  • southampton
  • Mot Tester
« Reply #6 on: 22 September 2010, 22:15:24 »
Right  read codes with better reader and still none listed.  Car starts every time so dont think its an imobilizer issue but we have discovered it only does it when hot and clears when cold.  After a bit of searching we've found someone listing the same problem and says a new crank sensor fixed it.
Mate wants to try that tomorrow as he needs the car so i'll let know how that goes.
Lee
« Reply #7 on: 22 September 2010, 23:22:56 »
If the rev counter drops to zero the crank sensor is a reasonable place to start in the absence of any codes, I suppose. :y
david036
  • Lancashire
« Reply #8 on: 22 September 2010, 23:53:18 »
Father in Law had this very issue with his, seems to be a very common problem.  Crank sensor was one of the main problems.  VX wanted about 700 to put right
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
lee4206
  • southampton
  • Mot Tester
« Reply #9 on: 23 September 2010, 19:14:08 »
Well so far so good  put new crank sensor on it and it seems to have cured the problem.
lee
« Reply #10 on: 25 September 2010, 10:37:56 »
Hmmm...it would have stored the code, wonder if its not such a hot code reader which only accesses the present codes and not the non-present/stored ones
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #11 on: 25 September 2010, 11:49:26 »
These engines use the crank sensor to run the rev counter, also a lot of the cheaper generic code readers will not communicate with Vx. diesels...
lee4206
  • southampton
  • Mot Tester
« Reply #12 on: 25 September 2010, 20:19:26 »
Hi Mark I tried a couple of readers first my elm one and then  a bosch kts200  which is a good reader also the lights were on when i read the codes and it said the eml was off on both readers so dont know what was happening there but since changing the crank sensor all is fine ( he says its better than ever).
lee
