Author Topic: Catalytic Test on V6 ??  (Read 2159 times)
24_Valve
  • Greater London
« on: 18 September 2010, 13:42:25 »
Seems like i have a damaged cat, but replacing both cat's will cost approx £600 with Vx trade club discount  :( some have said I need a back pressure test, are most garages equipped to do this & how much £ approx?
Also is there any sort of test port (13mm bolt hole) on the exhaust pipe between cat & back box ?? On other V6's there's often a 13mm bolt you can remove to put emissions probe into so you can determine which cat is failing..
thanks, steve
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
Re: Catalytic Test on V6 ??
« Reply #1 on: 18 September 2010, 14:19:27 »
As the cats are reliable (ignoring the 3.2 starting cats), genuine 2nd hand ones are a good option
markfree
« Reply #2 on: 18 September 2010, 20:25:05 »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 18 September 2010, 20:46:08 »
Try these guys :-
http://www.cats2go.co.uk/Default.aspx?PageID=15&CartID=1
Not being rude, but never buy crap aftermarket cats.
They are worth buttons in scrap value, and there is a reason for that.
ONLY buy decent, GENUINE cat's.
24_Valve
  • Greater London
« Reply #4 on: 21 September 2010, 23:18:22 »
Posted by TheBoy on 18. Sep 2010 at 14:19
might take a stroll down the breakers & have a look  ;)
24_Valve
  • Greater London
« Reply #5 on: 26 September 2010, 00:13:14 »
no omega cats on eternalcar site  ::) some on the bay of E for about £85 each side..?  Vx trade club discount quote from Andyc £300 each side  :o
Now wondering if new MAF sensor would be better than gambling on cats... latest reading today is showing CO content at natural idle as 0.07% which is very, very low! and 0.47% at fast idle which is very high! ??????????????
If my Cats or a Cat is/are destoyed, would my CO be so low at natural idle  :question
I'm now thinking MAF / engine management problem  :-/
Can't get to a tech2 so either way I need to take a gamble  :(
« Last Edit: 26 September 2010, 00:14:44 by silvercross1 »
« Reply #6 on: 26 September 2010, 00:51:59 »
Drop a PM to Loo-knee or have a look in parts for sale at cars being broken for spares. ;)
