Author Topic: Renault Megane  (Read 4501 times)
david036
  • Lancashire
Renault Megane
« on: 27 September 2010, 19:54:29 »
Have a suspected cam belt snap.  Is likely to have done valve damage or can this engine get away with just replacing the belt? Its a 1.6 16v Thanks
TOYOTA AYGO, CITROEN C1 ENGINE PARTS FOR SALE.  ENGINES HAVE LESS THAN 10MILES ON THEM.  CATS FOR SALE AS WELL.  HUGE SAVINGS ON DEALER PRICES
tidla
  • solihull
Re: Renault Megane
« Reply #1 on: 27 September 2010, 20:28:46 »
probably.  the last motor i recall to be "freewheeling" is the old fiat panda block. :(
Re: Renault Megane
« Reply #2 on: 27 September 2010, 20:36:24 »
Defo, modern high compression multi valve engines and a snapped belt equals bent bits!
Welung666
Re: Renault Megane
« Reply #3 on: 27 September 2010, 21:12:28 »
Dependant on the year it's possibly cheaper to source a 2nd hand head and just do a head swop on it with a new timing belt kit.
Re: Renault Megane
« Reply #4 on: 27 September 2010, 21:19:42 »
nope.. sure there is damage.. but at least wont cost like a v6 :-/
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Renault Megane
« Reply #5 on: 27 September 2010, 21:20:55 »
Just done that with an old 406 16v, got a s/hand head for a ton. Much cheaper than buying 16valves and the labour of changing them all :y
Edit, not seen a 16v Renault engine survive the belt breaking without damage :-/
« Last Edit: 27 September 2010, 21:24:32 by henryd123 »
other rides
Welung666
Re: Renault Megane
« Reply #6 on: 28 September 2010, 08:05:11 »
Tell you what, I'll give you a tenner for it ;) :P ;D
david036
  • Lancashire
Re: Renault Megane
« Reply #7 on: 28 September 2010, 08:15:09 »
If it makes any difference its a y reg 2000!!! Had only done 70k
mantagte
  • great yarmouth
    • omega bmw maverick
Re: Renault Megane
« Reply #8 on: 28 September 2010, 09:03:39 »
yes you can expect bent valves
recomended interval for belt change
is 72000 miles or 5 years
Re: Renault Megane
« Reply #9 on: 28 September 2010, 09:48:17 »
Welung666
Re: Renault Megane
« Reply #10 on: 28 September 2010, 14:06:21 »
Worth saving then!?
Where are you David? I may be able to help in the head department sourcing a 2nd hand head and fitting if needed :y
(I thought I'd better re-phrase that before you dirty mided lot start!)
henryd
  • west cornwall
Re: Renault Megane
« Reply #11 on: 28 September 2010, 15:09:55 »
Worth saving then!?
perish the thought ;D ;D ;D :y
other rides
david036
  • Lancashire
Re: Renault Megane
« Reply #12 on: 28 September 2010, 16:10:39 »
Worth saving then!?
Pm sent!!
Sixstring
  • Lydney, Gloucestershire
Re: Renault Megane
« Reply #13 on: 28 September 2010, 16:28:34 »
Lee..............
We wouldn't dream of it!!
Much.
Welung666
Re: Renault Megane
« Reply #14 on: 28 September 2010, 17:56:48 »
Worth saving then!?
Pm sent!!
and replied ;) :y
