Author Topic: (Rover) Any idea on removing CV joints  (Read 6290 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: (Rover) Any idea on removing CV joints
« Reply #15 on: 27 September 2010, 19:24:44 »
Been a few years since i've done a rover joint but if they are the same as the GM FWD ones, remove the boot, clear out as much grease as possible then have a feel round inside the joint for the circlip.
Use a good set of external circlip pliers in one hand, copper or soft face hammer in the other hand and pull the joint with other hand.....
Did i memtion you need three hands ;D
Andy
not the same as vauxhall,circlip is hidden,knock off with a hammer :y
other rides
« Reply #16 on: 27 September 2010, 20:19:06 »
Cheers guys :y
One side done, darkness, rain and extreme hunger prevented other side being done tonight.
I'm not allowed tea until I'm bathed :(. Hence laying in the bath, on OOF :P
« Reply #17 on: 27 September 2010, 20:40:11 »
Don't drop the laptop, that could have a shocking outcome!  ;D
« Reply #18 on: 27 September 2010, 20:49:53 »
The old one went in a few times ;D.  It lasted remarkably well, but I think the water eventually killed it  :'(
This HP one has yet to fall in the bath, but has been left out in the rain more than once (last time being Newent ;D)
« Reply #19 on: 27 September 2010, 21:08:27 »
 ;D ;D I've known people drop phones in baths..
I've even known a guy who took his Blackberry in the shower..
But I hadn't known anyone who'd dropped a laptop in the bath until now  ;D
« Reply #20 on: 27 September 2010, 22:24:10 »
IIRC the outer CV joint came off the drive shafts quite easy with a bit of a tap and I don't remember the driveshaft being held in the gearbox either but it was a couple of years since I have done the CV joints on mine and my daughters 25s ::)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #21 on: 28 September 2010, 03:01:00 »
The Gnome swears by his favourite tool the FBH ( Slapon of course). ;D
TuBy's new whipping boy.
« Reply #22 on: 28 September 2010, 09:15:46 »
Ah yes the FBH also know as the Negotiator, idiotometer ect ;D
« Reply #23 on: 28 September 2010, 19:42:15 »
Other side done tonight :)
Had trouble getting the boot clips tight - driveshaft end I used a cable tie, but the large one, had to use clip. Not convinced its tight enough  :-/
« Reply #24 on: 29 September 2010, 20:49:52 »
They're a right PITA ::) ::)
Hope you made sure there was no grease on the mating faces of the boot and the joint ;) ;) :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #25 on: 29 September 2010, 21:42:59 »
Join two cable ties together if needs be... I try to use the metal clips though, cable tied ones have come loose for me in the past.
