Author Topic: The old ways  (Read 5610 times)
Re: The old ways
« Reply #15 on: 08 October 2010, 21:58:59 »
LOL god memories, ok the average thumb nail is around 25thou thick easy to set your plug gaps!!
points? always did by eye as usually the shaft was always worn oval so it generally required a smaller gap to compensate, however usually set them with feeler gauges to start with,
timing? ignition on, set marks to static, loosen distributor and turn till the points spark, back very slightly and timing was spot on,
valve gaps? always done with engine running!! just tighten till they shut up do all stop engine use rule of eight etc, to check they all still have a little movement so wont burn out valves,
or the latest technolgy which was the spqr tappet adjuster, lol each click was equivalent to 1 thou so stting gaps was easy even though the valve gear was worn!!
fag papers were ideal for dropping the sump removing the big end bearingand mains, placing fag paper behind the bearing,put all back together, retorque and the rattling in the morning was cured for another 10k or so, used to be a hours job on the mk2 and 3 zodys!!! lol
carburettor setting? easy with gunsons colour tune to set the right mixture,
balancing them was also easy!!half inch bore pipe set just below the bellmouth, listen to it go to next and listen with practice you could get them spot on,  :y
Oh yes, very familiar, as was running your hand down the HT leads to find any leakage; you knew when you found it in those days before warning signs of "high voltage" under the bonnet!! :D :D :D :D ;)
That was when you got the bonnet spring catch in the back of your head, wasn't it??   ;D
Yep Ht, you obviously have been there!! :D :D :D ;)
Omegatoy
  • UK
Re: The old ways
« Reply #16 on: 08 October 2010, 22:03:48 »
nooooo that hurt to much!!!lol open bonnet at night down a quiet country lane with no street lights and give it a few revs, was like a light show when they were leaking!!
Re: The old ways
« Reply #17 on: 08 October 2010, 22:07:14 »
Absolutely right, but often we had other things to do at night so would take the pain during the day instead................ :P :P :P :D :D :D :D :D :D :) :)
« Last Edit: 08 October 2010, 22:07:51 by Lizzie_Zoom »
Re: The old ways
« Reply #18 on: 08 October 2010, 22:08:17 »
What are these 'other things' of which you speak?  :'( :'(
(Hopefully 'getting drunk' which I think I'll do now since I still don't have working bloody central heating, bah!)
Re: The old ways
« Reply #19 on: 08 October 2010, 22:40:09 »
I have done all the others, but never heard of the fag paper trick, did it really work?.... ::)
Re: The old ways
« Reply #20 on: 08 October 2010, 23:58:14 »
I think I've still got a colourtune in the garage somewhere. ::)
Great for proving the mixture on your SU carb was right at idle. Of course it was all over the show once you were moving with a bit of wear on the needle. ;D
Don't think I've ever owned a car with adjustable valve clearances. Even my Ital was an OHC.
Oh, unless you count Emma's old Fiesta with a Valencia engine. Ruddy thing. Never thought I'd have to adjust valve clearances again until that came along. Never thought I'd have to remove the margarine under the rocker cover to find the adjusters again either. ::)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: The old ways
« Reply #21 on: 09 October 2010, 00:49:34 »
We were posh so had a feeler gauge for tappets, points, plugs on the Austin A60 Cambridge. I remember topping up the carb with engine oil and putting Redex in the tank to allegedly improve performance. As an 18 year old was always trying to get the engine as quiet as possible and adjusted tappets excessively.
Re: The old ways
« Reply #22 on: 09 October 2010, 00:56:59 »
Remove air filter and pour down the carb, instant de-coke and the smoke would be the envey of James Bond... :D :D :D
Omegatoy
  • UK
Re: The old ways
« Reply #23 on: 09 October 2010, 08:07:12 »
yep on Zephrs/zodiacs, mgb,s cortina,s anglia,s wolseys, triumph spitfires, A40,s marina,s(and of course the old favourite was putting a small bolt in the end of the pressure relief spring to up the oil pressure ) 2000/2.5,s thrust bearings used to wear badly on those though and you couldnt do it sideways bumhats, ;D
Re: The old ways
« Reply #24 on: 10 October 2010, 00:27:14 »
They blew big ends with worrying ease..... ::)
I blew my Humber Scepter... big ends as soon as it hit the red line, in 4th with overdrive, ended up putting new shells in, could have saved myself some money.. ::) ::) ::)
