Author Topic: Theoretical engine question...  (Read 5231 times)
Welung666
« on: 10 October 2010, 21:04:47 »
...I've had a car in with an X30XE and a failed cambelt. Actually the bolt in the top belt guide snapped from, what I can tell anyway, not being tightened correctly. What would the advantages be between fitting a pair of X30 head to fitting Y32 heads?
I'm tempted to break it but just wanted some opinions first as this car is spotless and has only covered 82K since new!
Re: Theoretical engine question...
« Reply #1 on: 11 October 2010, 08:00:58 »
Nothing, the combustion bowls are the same cc (the lower compression of the 3.2 is achieved using a slightly shorter piston)
Welung666
« Reply #2 on: 11 October 2010, 08:07:43 »
That'll do me then, thanks Mark :y
« Reply #3 on: 11 October 2010, 17:51:06 »
Not that I will go to that length, but the implication is a bit more power by fitting 3l pistons to 3.2 engine?
« Reply #4 on: 11 October 2010, 18:07:52 »
Ah, talk of pistons TB is my scene! 8-) 8-)
So if you fit 3 litre pistons on top of 3.2 piston rods, you should get the longer stroke, higher compression, and a greater area of cumbustion in an enlarged chamber? :-/ :-/
« Last Edit: 11 October 2010, 18:59:50 by Lizzie_Zoom »
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #5 on: 11 October 2010, 18:10:22 »
didn't i read that there's a small difference in bore size....    ???   so depending on which way round it is....     one lot would get stuck, and the other lot would slap like a barsteward?
« Reply #6 on: 11 October 2010, 18:12:46 »
Ah, yes, if bore is different, that buggers my chances of ruling the universe ;D
« Reply #7 on: 11 October 2010, 18:39:08 »
Yep, 3.2 has a bigger bore. ::)
Doesn't mean there aren't suitable pistons around but if you wanted more compression skimming a shedload off the head and/or the block would probably be the path of least resistance.
« Reply #8 on: 11 October 2010, 18:45:20 »
As its a V, can't skim much off heads, unless to can build new coolant bridge?
« Reply #9 on: 11 October 2010, 18:48:26 »
Ahh, yes. Would have to be careful there.
« Reply #10 on: 11 October 2010, 18:52:26 »
Actually, given chrisgixers dilema, if you need more power than the 3.2, there is only one real option for an Omega....
« Reply #11 on: 11 October 2010, 18:59:07 »
Hello!!!!
No reaction then to my query?? ::) ::) ::)
« Last Edit: 11 October 2010, 18:59:29 by Lizzie_Zoom »
« Reply #12 on: 11 October 2010, 19:18:22 »
Hello!!!!
I think MaxV6 blew that idea out. Shame, as it seemed like an idea ;D
« Reply #13 on: 11 October 2010, 19:23:49 »
Hello!!!!
I don't know, actually. Then again, 3.2 has a longer stroke so would probably have shorter rods anyway. :-/
« Reply #14 on: 11 October 2010, 19:27:01 »
Thank you TB and Kevin! :y :y :y :y
Just wanted to know the technicalities or imposssibility of what I was suggesting ;D ;D ;D ;D ;D ;D
« Last Edit: 11 October 2010, 19:27:31 by Lizzie_Zoom »
