Author Topic: Full fat  (Read 4294 times)
Re: Full fat
« Reply #15 on: 23 October 2010, 21:33:12 »
You can drive around it but your constantly changing gear when travelling in traffic trying to avoid sitting at 1500 revs but the car is so much faster but not quite as fast as a Volvo S60 D5 ::)
Omegatoy
  • UK
Re: Full fat
« Reply #16 on: 23 October 2010, 22:46:33 »
lol but it wasnt for lack of trying though Pete? got to admit the d5 isnt slow!!!
Re: Full fat
« Reply #17 on: 24 October 2010, 10:31:46 »
There wasn't much in it and I did end up infront but only by driving at a silly speed, he had small testicles and a big brain whereas I am the opposite :-[
Omegatoy
  • UK
Re: Full fat
« Reply #18 on: 24 October 2010, 10:45:22 »
you cant do that!!!! yoiur chip is giving you a stutter!!! so it cannot be running well ;D and the td is a stately tourer not a petrol powered mv6 or the like!!! lolololol :y
Re: Full fat
« Reply #19 on: 24 October 2010, 19:30:54 »
yep just when boost is beginning to climb, foot hard down and it appears to be ok, but normal driving and its there worse on some cars than others, must be  something to do with the pump just beginning to throw extra fuel in for the boost,
just as an aside do any of the affected owners know the number of the chip? im wondering if he has purchased cheap chips and they are not running at the correct m,s, speeds>
i.e should be a faster acting chip? would need to compare the uprated make with the origional vaux chip i guess to find out?
I know he has tried a selection of chips, including some out of an unmolested TD ecu I had knocking around here.
Omegatoy
  • UK
Re: Full fat
« Reply #20 on: 24 October 2010, 20:26:49 »
aha!! i know he did a batch for another model, and only 78percent worked ok, turned out he had the wrong chips although they actually fitted and worked they were not working as should! they were not processing quick enough or something :o
