Pages: 1 [2] 3  All   Go Down
Author Topic: coil pack bolts  (Read 8108 times)
Re: coil pack bolts
« Reply #15 on: 25 October 2010, 18:49:41 »
The head cannot affect the displacement of the engine...
You're playing with words Jamie  ;) Of couse it wouldn't affect the displacement/swept volume, but the term displacement wasn't used. You could alter the engine size of an engine with a a bigger or smaller combustion chamber volume of a different head - I've no idea the differences between engines as to where the extra 200 cc came from.  :y :y
Re: coil pack bolts
« Reply #16 on: 25 October 2010, 18:51:39 »
Don't know maybe i should put a pic of the holes on here ?
If you're passing north Manchester I have some Time Certs you could use. Think Helicoil .... but better.  :y  :y  :y
Re: coil pack bolts
« Reply #17 on: 25 October 2010, 18:54:37 »
The question was, was it still a 2.2 with a 2.0l head. The reply is that changing the head cannot affect this.
In the case of 2.0/2.2, the difference is in the stroke.
Re: coil pack bolts
« Reply #18 on: 25 October 2010, 18:58:32 »
A lot of expence then, new pistons & a crank just for the sake of 200cc  ;)
Re: coil pack bolts
« Reply #19 on: 25 October 2010, 20:18:35 »
indeed, but I suspect the changes were made to comply with emissions
Re: coil pack bolts
« Reply #20 on: 26 October 2010, 00:24:49 »
So, the 2.0L has a single dis pack, I know because I have changed one, but the 2.2 has separate ones, I did not know that...... :-[ ::) ::)
Re: coil pack bolts
« Reply #21 on: 26 October 2010, 08:22:57 »
I'm sure it's a single coil pack staright onto the spark plugs ie no HT leads.  :y
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #22 on: 26 October 2010, 11:29:21 »
Ok  ;D heres some pics
[/img]
as you can see no threads.
Washing a car, is like making love to a beautiful woman.  caress the bodywork. Breathe softly and gently. And give every inch of it your loving attention. And make sure you've got a nice wet sponge.
Welung666
Re: coil pack bolts
« Reply #23 on: 26 October 2010, 12:19:36 »
Definately a 2.0 head! :(
Re: coil pack bolts
« Reply #24 on: 26 October 2010, 12:23:24 »
so why are there clearance holes in a 2.0 where there should be thread holes on a 2.2?  :-/
Just curious.  ;)
Welung666
Re: coil pack bolts
« Reply #25 on: 26 October 2010, 12:26:30 »
Just curious.  ;)
He has a 2.0 head with a 2.2 rocker cover fitted. The 2.0 rocker cover doesn't have the clearance holes ;)
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #26 on: 26 October 2010, 12:27:23 »
Well im confused now so does that mean i have lost the 200cc  :-?
Welung666
Re: coil pack bolts
« Reply #27 on: 26 October 2010, 12:28:27 »
No, as TB said up there ^ somewhere the difference is in the stroke of the pistons :y
majesticlarge
  • Gravesend Kent
Re: coil pack bolts
« Reply #28 on: 26 October 2010, 12:33:22 »
Ok sorry to ask again but it was starting to make my brain hurt :D I wonder why whoever done the work put a 2.0 head on and not a 2.2 unless there alot cheaper if it was me i would have on there what SHOULD be on there saying that the one thats been put on is so clean it was new or repainted the only thing that looks horrid is the cover as it has lost most of the silver
Welung666
Re: coil pack bolts
« Reply #29 on: 26 October 2010, 12:37:07 »
Your guess is as good as mine, could have been down to price, availability etc. As for the rocker cover again could be they picked the head up without one so just re-used to original. As long as it runs ok with the coil pack pushed down firmly I wouldn't worry too much.
« Last Edit: 26 October 2010, 12:38:09 by Welung666 »
Pages: 1 [2] 3  All   Go Up
